Power Up a Table Saw
Forum topic by traupmann posted 11-01-2010 05:37 PM 1008 views 0 times favorited 4 replies Add to Favorites Watch
View traupmann's profile
traupmann
124 posts in 2752 days
11-01-2010 05:37 PM
Topic tags/keywords: upgrade table saw 3 hp
Has anyone upped the power of a table saw from 1 1/2 hp to 3 hp? I have found that a higher HP on my router gets cleaner cuts, I am thinking that the same may be true by upgrading my Table Saw. (I want a 3hp Stop Saw, but the treasurer won’t allow it in the budget).
-- chas -- looking for Serta sponsorship to go Pro...
View Gene Howe's profile
Gene Howe
10352 posts in 3393 days
#1 posted 11-01-2010 07:21 PM
If you can get it mounted and the RPM is the same and the start capacitor isn’t a separately mounted unit, I can’t see a problem.
Some folks advocate using an 8” blade, as a cheaper alternative. Haven’t tried it …..yet.
View Chris Pond's profile
Chris Pond
63 posts in 3012 days
#2 posted 11-01-2010 07:33 PM
Have you try changing to a Thin Blade? I have hear this can help??? I found that the saw dose work better, but I don’t push my table saw.
-- Chris, Fernie, BC
View knotscott's profile
knotscott
7980 posts in 3341 days
#3 posted 11-01-2010 08:14 PM
Given adequate power, the motor size really shouldn’t matter to cut quality much. Things like precision of the parts, runout, belts, bearings, setup, and blade selection are the big contributors.
knotscott
#4 posted 11-01-2010 08:14 PM
