Building a Slab Flattener
Forum topic by ErikF posted 04-15-2017 02:59 PM 1399 views 0 times favorited 9 replies Add to Favorites Watch
View ErikF's profile
ErikF
621 posts in 2390 days
04-15-2017 02:59 PM
I’m currently building a large slab flattening setup. Figured I would share a bit about it in the case some of the build techniques could help someone else out.
Motion-
The first of these machines I built rode on a “V” shaped track. I turned down a set a wheels that matched the track profile. It worked but it wasn’t ideal for taking a decent pass, too much racking force/not very rigid.
This issue has been solved by using linear motion pillow blocks that ride on a shaft. The bearing wrap around the shaft and have a large footprint. They handle a much higher side force and don’t rely on weight to stay firmly on the rail. You could flip the machine upside down and all motion would still function smoothly. They’re expensive but work well.
Head Travel-
Two options…move the slab to the cutter or move the cutter to the slab. Moving the slab to the cutter makes the head assembly simpler and more rigid, but, it’s time consuming and leaves room for error and movement. On the first machine I moved the slabs up to the cutter. It was a pain.
This machine has 7” of vertical travel at the head. It is more complicated to build but the slab can remain stationary. Once one side is done, flip it and there should be no need for adjustment to get an even thickness.
The mounting plate for the motor and the spindle moves in a slot with a set of gibs. This allows small adjustments for head alignment and also allows the head to be snugged down during use. The head is raised and lowered using a 1” acme rod that has been turned down- similar to the adjustment screw on a vise.
Spindle
Could have used a router or dedicated CNC spindle motor but I wanted to have a wide range of tooling to run. Also didn’t want to drop a ton of cash on the spindle. We fitted a R8 spindle to a set of high speed pillow blocks to allow the use of collets as well as a wide range of carbide insert tooling. Anything that you can run on a Bridgeport vertical mill can be run on this setup.
Speed Control
To raise and lower the cutter speed there will be a variable frequency drive wired to the motor. This requires a 3phase motor (we are using a 5hp).
Still some odds and ends to finish up before it’s done. Should be done this week so I’ll give a final update. Feeds are manual.
Video
How do I get the pictures rotated?
-- Power to the people.
9 replies so far
View rwe2156's profile
rwe2156
3091 posts in 1626 days
#1 posted 04-15-2017 03:01 PM
Wow that is quite a piece of equipment!!
View Aj2's profile
Aj2
1721 posts in 1944 days
#2 posted 04-15-2017 03:09 PM
Ya that badass I have no need for one but I like it.
-- Aj
View hotbyte's profile
hotbyte
991 posts in 3121 days
#3 posted 04-15-2017 03:20 PM
Cool. Be sure to post video of it in use :-)
View Nubsnstubs's profile
Nubsnstubs
1408 posts in 1876 days
#4 posted 04-15-2017 03:23 PM
Pretty good job there, Erik. I can’t help with the picture rotation, but someone just posted a thread on “Posting Pictures” a couple days ago. You might find something there to help.
You show a fly cutter in one of the pictures, but how are you tightening it to the spindle. Are you going to use a drawbar like most mills use?
I watched the video, and it looked like there was a lot of distance from the end of the collet and the first bearing. That might cause chatter if it’s the case. Correct me if I’m wrong. Other than that, It looks like you’ve got a winner there. I’ll be watching for your next report on progress and hopefully see a finished slab.
I thought about doing something like that to video my turnings, but decided it was too much work for making videos that only I will see. ............... Jerry (in Tucson)
ErikF
#5 posted 04-15-2017 03:29 PM
Pretty good job there, Erik. I can t help with the picture rotation, but someone just posted a thread on “Posting Pictures” a couple days ago. You might find something there to help.
I watched the video, and it looked like there was a lot of distance from the end of the collet and the first bearing. That might cause chatter if it s the case. Correct me if I m wrong. Other than that, It looks like you ve got a winner there. I ll be watching for your next report on progress and hopefully see a finished slab.
- Nubsnstubs
There is a drawbar to hold the collets and tooling.
One thing still missing is the table. The slabs will rest a few inches bellow the carriage so the cutter won’t be sticking out nearly as much as in the video.
View Don W's profile
Don W
18962 posts in 2713 days
#6 posted 04-16-2017 11:55 AM
you need to put that on wheels. The traveling flattener!
View Bill White's profile
Bill White
5072 posts in 4106 days
#7 posted 04-16-2017 12:08 PM
That is some smooooth operator.
Well done.
Bill
-- bill@magraphics.us
View OSU55's profile
OSU55
1865 posts in 2135 days
#8 posted 04-16-2017 02:10 PM
The function of the machine is explained, but it would be interesting to understand the need. How many slabs do you flatten annually? How much $ will be in the machine? Curious about the ROI.
View Andybb's profile
Andybb
1278 posts in 749 days
#9 posted 04-27-2017 11:22 PM
Beefy!!!
-- Andy - Seattle USA
