jointer technique question
Forum topic by mstenner posted 11-01-2010 02:19 PM 2115 views 1 time favorited 8 replies Add to Favorites Watch
View mstenner's profile
mstenner
57 posts in 3180 days
11-01-2010 02:19 PM
Topic tags/keywords: jointer milling
I just got my first jointer (a Jet JJP-12HH, first planer too, for that matter) and am so far pleased. I’ll post a review after a bit more time with it. I have a technique question, though. I’m sure I have the basic technique down, but I suspect I’m doing something a bit wrong.
When face-jointing, I get a “bump” about 8 inches back from the leading edge of the board. I suspect it happens when I perform a less-than-perfect hand-off from pressure on the infeed side to the outfeed side. On one board, I tried running it through in both directions, which worked, but clearly isn’t a good idea with less friendly grain orientation.
Do others get this bump? Is there a trick to how you do your “hand-off”?
-- -Michael
8 replies so far
View snowdog's profile
snowdog
1164 posts in 4009 days
#1 posted 11-01-2010 02:25 PM
Are you talking about “snipe”? If you are then yes many of us have the problem :)
Take a look at this post:
http://lumberjocks.com/topics/12326
mstenner
#2 posted 11-01-2010 02:38 PM
snowdog: no, it’s not really snipe. First, this is a jointer, not a planer (well, the machine is both, but I’m using it in jointer-mode). Second, it’s not a too-deep cut for the first couple inches. It’s a too-shallow cut from inch-8 to inch-12 or so.
BoiseJoe: I might be applying pressure too near the blades. There’s a guard directly over them, but I am applying pressure a couple inches away (on the infeed side first, then switching to outfeed). Should I not apply pressure so close? I’m pretty sure the outfeed table is not too high. I tuned it so that a straightedge on the outfeed table just barely touches the blade (I can hear the “whisk-whisk” sound, but it doesn’t lift the straightedge).
-- -Michael
mstenner
#3 posted 11-01-2010 02:48 PM
BoiseJoe: Thanks, I’ll give it a shot. I’m slightly dubious that the particular alignment you describe (relative height of cutter and outfeed table) can remain dead-on when switching back and forth between modes. So it’s possible that it’s shifted a bit. Since this is the first time I’ve tuned a jointer, it’s also possible I just screwed it up!
-- -Michael
mstenner
#4 posted 11-01-2010 02:56 PM
Well, I just had the thing shipped across the country and slid down the steps into my basement, so I wasn’t shocked that it needed a little love!
-- -Michael
View Gene Howe's profile
Gene Howe
10540 posts in 3455 days
#5 posted 11-01-2010 03:24 PM
My technique is to only apply enough pressure on the infeed end to keep it against the fence and on the table. That way when I switch to the outfeed end, there a less abrupt change of pressure.
Caveat: the outfeed table must be dead on even with the cutters. Mine is fixed, so I don’t have that adjustment to worry about.
View Lochlainn1066's profile
Lochlainn1066
138 posts in 2803 days
#6 posted 11-02-2010 08:48 PM
I’m tossing around the idea of selling my jointer. I can’t use the thing worth spit. I’m faster with hand planes. I can’t get it set accurately for some reason and it always ends up bowing the board across either width or length and I sure can’t get rid of twist. I only make it worse.
With a #5 jack and a scrub plane I can do it faster, quieter, and get a workout.
Lest I sound like a hand tool snob, you can pry my cheapie Delta 12” planer from my cold, dead hands. Or unless you trade me for a bigger one! :)
-- Nate, thegaragestudio.etsy.com
View Cato's profile
Cato
701 posts in 3339 days
#7 posted 11-03-2010 12:47 AM
Charles Neil has a very good you tube video for techniques on the jointer. i watched it twice and then I had it down pretty well. Let the jointer do the work and don’t overly apply pressure.
After I get a few inches of board past the cutter head of the jointer I apply pressure only to the outfeed table and drag the remainder of the board over the cutter head. Gradually with more passes it will begin to cut the entire length.
I like using the jointer and watching it straighten and flatten a board.
View Camper's profile
Camper
232 posts in 2882 days
#8 posted 11-03-2010 01:37 AM
hi, i recently got a used jointer (my first one) and a fellow LJ sent me this link which I think is one of the better publications out there talking about jointing techniques. Do not let the fact that its for a very old craftsman jointer turn you off. The techniques are applicable across the board and I think I learnt a great deal from it. Hope it helps.
-- Tampa-FL
