Drill Press Rack and Pinion Help
Forum topic by Scott posted 04-15-2017 02:35 AM 520 views 0 times favorited 4 replies Add to Favorites Watch
View Scott's profile
Scott
116 posts in 1531 days
04-15-2017 02:35 AM
I Picked up a new drill press tonight. It is a floor model made by an off brand. The height adjustment isn’t working on it though. It uses the rack and pinion to change height. Nothing looks visually wrong with the rack. I’ve taken the whole thing apart and the gears work fine together. Anyone have any advise on getting it to work? It seems like it was binding before….
runswithscissors
2874 posts in 2201 days
#1 posted 04-15-2017 04:36 AM
Check whether the crank has a set screw to fix it on the pinion shaft. If that’s loose or missing, it could be your problem.
View teejk02's profile
teejk02
485 posts in 1301 days
#2 posted 04-15-2017 03:50 PM
I’ve owned 2 different Delta’s. The rack and pinion on both was always “clunky”. The “rack” “floats” on the column and is supposed to be self aligning but it’s not really a precision fit. For yours not to work at all is odd though. Is it worn to the point where the pinion doesn’t mesh correctly?
Scott
#3 posted 04-15-2017 07:51 PM
Well I took it apart and saw no signs of excessive wear. I ended up taking all the gears out and cleaning them thoroughly. One of the gears was installed backwards so they were trying to work in opposite direction. I reassembled it correctly and everything works like a charm now!
teejk02
#4 posted 04-15-2017 09:22 PM
- Scott
Sometimes we have to take stuff apart to see how they work! I’m about 50/50 on getting it back together right but glad you figured it out. My next suggestion was going to be to shim the rack away from the column.
