Let's see your chop saw stations.
Forum topic by pontic posted 04-15-2017 12:28 AM 1359 views 0 times favorited 18 replies Add to Favorites Watch
View pontic's profile
pontic
558 posts in 516 days
04-15-2017 12:28 AM
Mine is the Fred Flintstone model but its very accurate and gets the job done. The saw dust falls neatly into the tub below the saw.
-- Illigitimii non carburundum sum
18 replies so far
View Rrrandy's profile
Rrrandy
212 posts in 386 days
#1 posted 04-15-2017 04:40 AM
Very simple but well tuned.
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
pontic
#2 posted 04-15-2017 12:00 PM
Simple is always best.
View Ron Aylor's profile
Ron Aylor
2135 posts in 555 days
#3 posted 04-15-2017 01:58 PM
The epitome of simplicity …
-- Ron in Lilburn, Georgia.  Knowing how to use a tool is more important than the tool in and of itself.
woodbutcherbynight
3961 posts in 2316 days
#4 posted 04-15-2017 10:17 PM
pontic
#5 posted 04-15-2017 11:32 PM
Nice rig!
View Texcaster's profile
Texcaster
1271 posts in 1581 days
#6 posted 04-15-2017 11:59 PM
My base is an old Foot Locker signage frame from my shopfitting days. Cement bags for ballast, I add fences as needed.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View Bob5103's profile
Bob5103
86 posts in 741 days
#7 posted 04-16-2017 12:25 AM
Mine is built in, gives me 8’ to the right and about 14’ to the left. My router table is built into the same counter. DC is a ducted central vac.
pontic
#8 posted 04-16-2017 02:10 AM
All good Keep ‘em coming.
View BillyDoubleU's profile
BillyDoubleU
152 posts in 349 days
#9 posted 04-16-2017 02:19 AM
- pontic
That’s a pretty cool idea.
I’m getting ready to build my stations and am gathering ideas. Thanks for that.
-- "But I’ve bought a big bat. I’m all ready you see. Now my troubles are going to have troubles with me!” ~ Dr. Seuss
View Rich's profile
Rich
2294 posts in 497 days
#10 posted 04-16-2017 03:52 AM
Nice setup Bob5. I dream of being that organized, but just never get all the way there.
-- No matter how much you push the envelope, it'll still be stationery.
View Desert_Woodworker's profile
Desert_Woodworker
1308 posts in 1122 days
#11 posted 04-16-2017 04:00 AM
When I was a young man
You test safety by if there is a breeze on your arm hairs- Seriously we used equiptment like this on the job site, in AZ; 90’s and 45’s spot on…. This station is a memory but it is kept in the corner to cut ABS.
Now that I am an old man…
I have and used this DeWalt made in the USA (1992) to today, commercially with a Forrest chop saw blade… and as AVE would say it “choochs”
-- Desert_Woodworker
View Harryn's profile
Harryn
62 posts in 2495 days
#12 posted 04-17-2017 02:21 PM
I used the stand and wheels of an old grill. Built up the sides to match the height. Needs a concrete block for stability, but works great.
View TungOil's profile
TungOil
841 posts in 402 days
#13 posted 04-17-2017 02:44 PM
I struggled with how to integrate my chop saw into my radial arm bench for a while. The biggest issue with my compound slide miter saw is how far off the wall it needs to sit- it just takes up too much space. What I came up with is this linkage arrangement that allow me to store the saw tight against the wall when not in use but pull out quickly when I need it. Right now I’m using a roller stand to support long work pieces but I’ll probably come up with something better when I have time. I still prefer the RAS for 90 deg. cross cut work, I really only use the chop saw for angled cuts.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Ed's profile
Ed
85 posts in 1182 days
#14 posted 04-23-2017 10:51 PM
Love the articulating compound miter saw, this allows me to have a router table set up on the other side of the island. I have dust collection hooked to the saw and at the bottom as well. Wife did a little sewing from an old bed sheet for the shroud. Dust is well contained. The stops are simple but work well. Thanks
-- Ed, Dawson Creek “It is easier to get forgiveness than permission”
View harriw's profile
harriw
128 posts in 2115 days
#15 posted 04-23-2017 11:29 PM
Here’s mine. 8 1/2 feet to the left, around 6ish to the right. If I wheel my planer cabinet out of the way, I can get more like 12ish to the right.
Had every intention originally of making side fences with a sliding stop block, self-adhesive measuring tape with a cursor, etc. But just haven’t gotten around to it yet. Honestly I haven’t really felt the need for it – my crosscut sled on the table saw can handle most of that sort of thing. Besides, I tend to use the bench space for other things as well – particularly on the left side.
4” port from the dust collector sits in the bottom in the back, with sloped sides “funneling” into it. As you can see it gets pretty dusty back there, but it stays back there for the most part. No appreciable amount of dust makes it out to the front. Maybe a tiny bit, but that’s easy to fix with the shop-vac right there underneath.
I rigged an extension on the blast gate to open/close it easily without bending over.
I also have a craftsman RAS that I’d LOVE to build into that bench as well. I intended to build it into the right end of this bench where the grinder is, but there just isn’t enough space. My lumber rack is on the far side of that grinder, and I couldn’t fit 8’ sheet goods (or 8’ boards for that matter) if I build in the RAS there. Maybe I’ll come up with a way someday…
-- Bill - Western NY
