DW 735 Blowing the Ckt Breaker...
Forum topic by SteveL posted 02-06-2008 06:06 AM 1497 views 0 times favorited 2 replies Add to Favorites Watch
View SteveL's profile
SteveL
167 posts in 3673 days
02-06-2008 06:06 AM
Topic tags/keywords: question
After 3 years of planing anything I put through it, my Dewalt 735 13” planer is now tripping the circuit breaker. It typically will start, but if I then turn it off, and on, it will trip the 20A breaker in my shop panel (nothing else on this circuit) with no load (no wood to chew on). Opened it up and there’s nothing stuck in it and the cutter head turns ok.
I have changed the blades and they’re reasonably sharp, so it’s not overheating. It will do this from a cold start if you power it up for a few seconds, then try to power it up again.
I’m thinking that maybe this is a faulty brush in the motor. Anyone else have experience with replacing the brushes in these? Do they behave like this when they need to be changed?
-- SteveL
2 replies so far
View GaryK's profile
GaryK
10262 posts in 3893 days
#1 posted 02-06-2008 06:11 AM
Brushes and bearings are really the only thing that can go wrong with a motor, if you haven’t burned it up.
Sounds like it will probably be the brushes. Not a bad idea to change them after 3 years. It’s a cheap first
step.
View DaveH's profile
DaveH
400 posts in 3683 days
#2 posted 02-06-2008 06:31 PM
You might try swapping the 20amp breaker in the panel with another. Breakers can wear out.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
