Replace deck boards. Nail or screw?
Forum topic by MHW posted 04-14-2017 05:25 PM 1341 views 0 times favorited 11 replies Add to Favorites Watch
View MHW's profile
MHW
8 posts in 609 days
04-14-2017 05:25 PM
Topic tags/keywords: deck replace replacement decking nails screws question advice
I want to replace the deck boards. The current deck boards are adhered with nails. Considering Midwest weather changes, should I use nails, rather than screws, when replacing the boards to allow for better expansion/contraction?
11 replies so far
View buckbuster31's profile
buckbuster31
254 posts in 717 days
#1 posted 04-14-2017 05:28 PM
I would, hands down use screws. no doubt in my mind.
View bonesbr549's profile
bonesbr549
1576 posts in 3269 days
#2 posted 04-14-2017 05:36 PM
Man, I don’t know of any contractors worth their salt that still nail decking. I’d go composite now, and connector clips.
View LiveEdge's profile
LiveEdge
594 posts in 1822 days
#3 posted 04-14-2017 05:46 PM
I think the reality with a deck is you aren’t “allowing” for expansion/contraction, you are doing your best to reduce/remove it. First you select a wood with good stability and outdoor resistance, and second you screw it down every 18 inches to do your best to keep it from moving. That’s my take on it anyway.
View Murdock's profile
Murdock
129 posts in 2686 days
#4 posted 04-14-2017 05:47 PM
I have stainless steel screws on my deck here in Minnesota and have been very happy with those for aprox 8 years (cedar boards)
I know my parents used nails on their deck and have had a few nail pops every year to deal with, not a huge deal I guess but I have never had to do anything with my screws.
-- "Anyone who has never made a mistake has never tried anything new." - Albert Einstein
View CharlesA's profile
CharlesA
3351 posts in 1999 days
#5 posted 04-14-2017 06:06 PM
I used Camo Marksman and really liked it:
http://www.camofasteners.com/
5176 posts in 2695 days
#6 posted 04-14-2017 07:30 PM
- buckbuster31
^^^^^^the right answer.
View JCamp's profile
JCamp
877 posts in 752 days
#7 posted 04-14-2017 07:40 PM
I have built them using both. I highly recommend screws over nails. For me nails seem to loosen over time. I’ve even had a few break. I’ve never had any trouble like that from screws. Make sure u use the appropriate screws that wont rust from being n contact with the deck boards (or constant exposure to the elements)
If you have many to do I advise to invest in a impact driver verse a normal drill
-- Whatsoever thy hand findeth to do, do it with all thy might
View Ted78's profile
Ted78
401 posts in 2202 days
#8 posted 04-14-2017 07:47 PM
Going to add my voice to the DEFINITELY screws crowd. Worked at a nature center where they had built a long boardwalk through the wetlands. Pounding down the nail heads that popped up and keeping it in good repair in general was a nightmare of a task. They did eventually get rid of it and made an earthen bridge across the wetlands.
-- Ted
View JayCee123's profile
JayCee123
200 posts in 966 days
#9 posted 04-16-2017 03:29 PM
All above comments are very good info. I’d go with a “epoxy coated” deck screw, unless I was putting down Cedar or Redwood, in which case I’d use Stainless Steel.
I did have a couple of clients many years ago that would not invest in the additional cost of screwing down deck boards for their decks. I shot Paslode nails with a framing nailer they were specially coated with some sort of protective coating and glue designed for use with Pressure Treated lumber. These nails have actually performed pretty well … but my preference is to use a screw.
View patcollins's profile
patcollins
1687 posts in 3067 days
#10 posted 04-16-2017 04:38 PM
- CharlesA
DId you use real wood? Any problems with the holes collecting water?
View ArtMann's profile
ArtMann
1147 posts in 1018 days
#11 posted 04-17-2017 12:45 AM
I have always built decks and steps with stainless steel deck screws or in a few cases coated deck screws. However, I had an occasion to hire someone else to build a deck for me at our farm house about 150 miles away. Instead of screws, he used ring shank nails that can be shot from a nail gun. They will not pull out. If you ever tried it, you know what I mean. My problem with them is they are very hard to drive with a hammer. The adaptation of these nails for pneumatic nail gun use makes them a practical alternative. If you have a lot of deck work to do, it might be worth a look. They are faster than screws and an impact driver and work just as well.
