3M77 - Spray Adhesive
Forum topic by ChunkyC posted 10-31-2010 10:59 PM 1610 views 1 time favorited 15 replies Add to Favorites Watch
View ChunkyC's profile
ChunkyC
856 posts in 3220 days
10-31-2010 10:59 PM
Do you guys use 3M 77 for anything other than fixing patterns to wood? I’ve been using 3M 77 for a few things around the shop lately and was curious what you think.
One thing that I did last week was that I needed to face join two pieces of MDF for a jig. I new that I was going to reinforce it with screws but I wanted to glue it too. Using yellow glue can be pain, as you know, because putting a clamp on it is like walking on ice.
Tonight I made the drawer for my new DP table. It’s a small drawer, about 8×10 x 4 and it’s installed w/out slides. I wanted a way of stopping the drawer so that I don’t pull it out and dump everything on the floor. So I 3M 77’d a short piece of hardboard to bottom of the drawer frame. Thinking that if I couldn’t tip the drawer enough to get it over the cleat, it would be a lot easier to remove. It was quick and easy.
Anyone else using 3M 77, or something similar, around the shop?
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
15 replies so far
View Sawdust4Blood's profile
Sawdust4Blood
403 posts in 2987 days
#1 posted 10-31-2010 11:36 PM
It works well for lining boxes and drawers for jewelry boxes. I don’t use it for anything that requires structural strength though.
-- Greg, Severn MD
View 8iowa's profile
8iowa
1580 posts in 3727 days
#2 posted 10-31-2010 11:44 PM
I use 3M77 to attach wet/dry paper to glass plates for sharpening. When worn, the paper can be removed with a putty knife and mineral spirits. I understand that the 3M90 adhesive is much more permanent.
TopamaxSurvivor
18247 posts in 3642 days
#3 posted 11-01-2010 12:19 AM
I haven’t used it for several years. Thanks for the reminder about how handy it it :-))
View TJ65's profile
TJ65
1376 posts in 3016 days
#4 posted 11-01-2010 10:40 AM
If that is the spray stuff, I use it sometimes to adhere flocking inside boxes.
-- Theresa, https://www.facebook.com/derrymore/
View ghazard's profile
ghazard
382 posts in 3475 days
#5 posted 11-01-2010 02:57 PM
I have a can on the shelf. As mentioned, it is great for box interiors and adhering sandpaper to something…or other similar uses. I even used it to adhere cardstock paper to some melamine to make a temporary sign. Best part is that while the bond is strong and will hold whatever you are gluing without the edges peeling, it is not permanent. So, you can replace the sandpaper pretty easily and not ruin the substrate. I pulled the cardstock off the melamine, in one piece, and now have good-as-new melamine.
I agree with sawdust that I would not use it for anything requiring structural strength…its not THAT strong.
A can on the shelf is a must in my shop…I mean garage! :)
Greg
-- "Hey, you dang woodchucks! Quit chuckin' my wood!"
View Gene Howe's profile
Gene Howe
10355 posts in 3394 days
#6 posted 11-01-2010 03:10 PM
Theresa,
Do you use it instead of the colored lacquer? Does it work well? Coverage OK?
Thanks,
8iowa
#7 posted 11-01-2010 03:19 PM
Another tip:
If possible spray 3M77 outside, or have a lot of back-up paper. The overspray can create a “tacky” mess that is hard to clean up.
ghazard
#8 posted 11-01-2010 03:42 PM
8iowa is exactly right…and make sure your car is not down wind from you when you spray it in the driveway! :)
Greg
View Chris 's profile
Chris
1879 posts in 3957 days
#9 posted 11-01-2010 04:12 PM
I use it for sticking sandpaper as well.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View TJ65's profile
TJ65
#10 posted 11-02-2010 06:32 AM
Hey Gene, What I do is use a layer of PVA glue watered down a bit to get an even coat, then put in the flocking. this is because I am really lazy- when it’s all dry I then use a spray of adhesive to do another layer of flocking. It can be a bit fiddly on some of the smaller boxes (if you dont want to get glue everywhere I sometimes make a template so I don’t spray the unwanted areas) but works well on large pieces. And the flocking is thicker too.
Gene Howe
#11 posted 11-02-2010 02:29 PM
Hey Back, Theresa.
Thanks for the info and the PM.
View Howie's profile
Howie
2656 posts in 2889 days
#12 posted 11-02-2010 03:29 PM
Now here is a prime example of what this site should be about without the malarky.
Someone asked a simple question, got simple informative answers and we all learned something.
Thanks TJ and all the rest with suggestions. :-)
-- Life is good.
View Gregn's profile
Gregn
1642 posts in 2949 days
#13 posted 11-04-2010 08:56 PM
I use it in place of double sided tape for aligning drawer fronts to drawers.
ChunkyC
#14 posted 11-05-2010 03:28 AM
Gregn: Great idea.
Something other than sticking paper.
View doyoulikegumwood's profile
doyoulikegumwood
384 posts in 3958 days
#15 posted 11-05-2010 03:47 AM
i used it to laminate the 2 pieces of melamine that are the top of my work table its held great for 6 years and counting
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
