Branding/stamping wood projects?
Forum topic by jacarn1 posted 04-14-2017 01:55 AM 865 views 0 times favorited 13 replies Add to Favorites Watch
View jacarn1's profile
jacarn1
1 post in 501 days
04-14-2017 01:55 AM
Not sure if I have this in the right place but I’m wondering if there is any way to brand a logo into into your wood projects without a branding iron? I don’t want to burn it into the wood I want some sort of a stamp that I can hammer the logo into the wood with kind of like a leather stamp but I don’t know of anything or where to get one. Can anyone give some feedback??
13 replies so far
MrUnix
6846 posts in 2283 days
#1 posted 04-14-2017 02:01 AM
Don’t know about stamping with a hammer, but I do heat transfers which are similar to a stamp. Just print out the logo/design on a laserjet and heat transfer with a soldering iron or other similar heat source. No burning – just transfers the image to the wood. Unlike a rubber stamp, you can make the image as big or small as you need and use different ones for different projects… like adding a date, material used, whatever you want – it’s up to your imagination.
View BillyDoubleU's profile
BillyDoubleU
152 posts in 525 days
#2 posted 04-14-2017 02:42 PM
The only thing off the top of my head that could work would be something like and auto-punch.
Get the logo you want and use the auto-punch to apply the strike. It’s less jarring than a hammer.
I don’t know all the sizes they come in but it’s worth a look.
-- "But I’ve bought a big bat. I’m all ready you see. Now my troubles are going to have troubles with me!” ~ Dr. Seuss
View ScottM's profile
ScottM
662 posts in 2230 days
#3 posted 04-14-2017 03:05 PM
Don t know about stamping with a hammer, but I do heat transfers which are similar to a stamp. Just print out the logo/design on a laserjet and heat transfer with a soldering iron or other similar heat source. No burning – just transfers the image to the wood. Unlike a rubber stamp, you can make the image as big or small as you need and use different ones for different projects… like adding a date, material used, whatever you want – it s up to your imagination.
- MrUnix
I think I’ve seen you mention that before; heat transfer. Can you provide a little more info on exactly how that works?
BillyDoubleU
#4 posted 04-14-2017 03:29 PM
- MrUnix
I think I ve seen you mention that before; heat transfer. Can you provide a little more info on exactly how that works?
- ScottM
https://youtu.be/cEdmQRduUww
MrUnix
#5 posted 04-14-2017 03:59 PM
- BillyDoubleU
Good video showing the process… just a couple of notes. First, I had an old soldering iron laying around, which had a threaded tip. I just put a flat headed carriage bolt in it’s place, filed slightly convex and smooth, to give it more surface area similar to what is shown in the video with the wood burning kit. And secondly, he says that wiping it with poly or other type finish might smear the image – it doesn’t. The toner used by laser printers is mixed with a polymer, and it gets melted in the process of transferring the image to the paper. The heat transfer to wood does the same thing – melts the toner/polymer, which then hardens when cooled. I typically use a homemade wipe-on poly as a finish, which is just a 50/50 mix of poly and mineral spirits. I have never had one smear yet.
View Kazooman's profile
Kazooman
1089 posts in 2036 days
#6 posted 04-14-2017 04:20 PM
The transfer technique is the same as the one used for applying the mask to copper-clad printed circuit board prior to etching. For that I just use an old steam iron we had laying around (without any steam!). The quality of the transfer depends to a degree on the paper used. Smooth hard surfaced paper works best. Many have found that pages from a magazine work great.
View bbasiaga's profile
bbasiaga
1239 posts in 2079 days
#7 posted 04-14-2017 04:25 PM
You can go really old school and get a set of letter and number punches from Harbor Freight. Less than 10 bucks IIRC. Tap out your desired phrase and fill in with wax pencil before finishing.
Brian
View jimintx's profile
jimintx
807 posts in 1668 days
#8 posted 04-14-2017 04:28 PM
I like the idea of doing something to mark the product, without the branding iron. Happy to see this thread.
-- Jim, Houston, TX
View Madmark2's profile
Madmark2
381 posts in 672 days
#9 posted 04-14-2017 04:49 PM
Cheap <$200 laser:
Link
M
View papadan's profile
papadan
3584 posts in 3452 days
#10 posted 04-14-2017 05:34 PM
If you don’t want to burn it in, Take your logo and info to Staple or Office Depot and they can make a rubber stamp for you and just stamp it with ink on anything.
jimintx
#11 posted 04-14-2017 10:25 PM
Cheap <$200 laser …
M
- Madmark2
Maybe be cheap for a laser, but not what I’d call cheap for a mark on my shop products.
-- Jim, Houston, TX
View shipwright's profile
shipwright
8031 posts in 2882 days
#12 posted 04-14-2017 11:52 PM
There’s always marquetry.
View Dave Polaschek's profile
Dave Polaschek
2397 posts in 666 days
#13 posted 04-15-2017 01:41 PM
Infinity Stamps make stamps for marking wood. Haven’t bought from them, but someone mentioned them to me.
I’m buying a $70 Chinese laser engraver from eBay that I’m going to experiment with for marking items, but if that doesn’t work, the stamp will be next on my list.
-- Dave - Minneapolis
