Loose arbor on my table saw
Forum topic by mspain77 posted 04-13-2017 08:04 PM 614 views 0 times favorited 3 replies Add to Favorites Watch
View mspain77's profile
mspain77
62 posts in 815 days
04-13-2017 08:04 PM
Topic tags/keywords: question tablesaw
Hey guys and gals,
You’re all always so helpful and full of knowledge every time I have a question and I am truly grateful. So grateful that here’s another one for you. ;)
I’m literally on hold as I type this with the Bosch tool company because I just discovered my arbor has a little play in it. I’ve Googled and found numerous articles about run out. I have verified that my saw blade is dead flat and my arbor nut and washer merry up well also, and with no blade on I can wiggle the arbor just a fraction. It’s ever so slight, but I can hear some clicking when I move it. My cuts are still pretty good and glue up ready, but you notice the side to side movement as the blade slows down and comes to a stop.
My saw is out of warranty by 3 months, so repairs would be out of pocket, which is not feasible right now. My question is: How big of an issue is this right now? I don’t recall this issue when I first got the saw (though I know much more now than I did a year ago), so I don’t know if it is slowly loosening up or has always . Can I keep using this as long as my cuts are true or should I be worried about a saw blade coming loose?
Thanks again in advance for all of your feedback.
-- It's a BEAUTIFUL day to cut some wood & build something!
3 replies so far
View LDO2802's profile
LDO2802
158 posts in 454 days
#1 posted 04-13-2017 09:17 PM
Are the mounts on the inside of the saw tight. Open it up and ensure the mounts haven’t come loose a bit.
mspain77
#2 posted 04-14-2017 02:51 PM
LDO2802, I’m not sure which “mounts” you are referring to. If you mean the motor mounts, yes they are secure. The play is within the motor housing where the arbor is attached.
LDO2802
#3 posted 04-14-2017 03:25 PM
Yes, those were the ones. I am not sure then my friend. I would assume if your cuts are still smooth and level, I wouldn’t worry too much about it. If they start becoming uneven or you get tearout more than usual, then start worrying about it.
