Question About Planer Functionality & Safety
Forum topic by Jangles posted 04-13-2017 05:26 PM 1127 views 0 times favorited 7 replies Add to Favorites Watch
View Jangles's profile
Jangles
3 posts in 611 days
04-13-2017 05:26 PM
I cut a few different species of wood lengthwise a while back and joined them together with wood glue to make a nice pattern. It’s now a 1”x7” board. the board is now configured: 2” red oak, 1” poplar, 1” red oak, 1” poplar, 2” red oak. Well, the red oak and poplar are up to 1/16 of an inch taller or shorter on the unglued top. Picture running your hand across the 7” face and clearly feeling a height change when going from oak to poplar or vice versa.
Anyway, I figured I’d sand this down. After about 30 minutes with little progress, I realized I need another solution. I know how I SHOULD HAVE done this. I should have jointed the boards, then planed them to even thickness. Then I wouldn’t have this problem. Unfortunately I don’t own either of those tools.
Can I run this through a planer? Would that work? Is it dangerous with the way I have explained how the wood is configured? Or should I be safe and spend 5 hours sanding the darn thing.
7 replies so far
19451 posts in 2059 days
#1 posted 04-13-2017 05:40 PM
I assume you mean its 1’ x 7’ and not inches. So these pieces are glued end grain to end grain right? Are they flat on the bottom? If they are flat on the bottom, it will be fine to run thru the planer. Make sure the planer is set for the highest dimension and taking a light pass. I would do this in very light passes.
View HokieKen's profile
HokieKen
7129 posts in 1341 days
#2 posted 04-13-2017 07:14 PM
As long as you have 1 flat side, it will be fine.
-- Kenny, SW VA, Go Hokies!!!
5177 posts in 2696 days
#3 posted 04-13-2017 07:16 PM
My guess is it’s 1” thick and 7” wide, should be fine going through a planer…is there something that makes you hesitant? You do need a flat surface on one side. Or go old school: hand plane.
Jangles
3 posts in 611 days
#4 posted 04-13-2017 07:27 PM
It is a 7 inch wide board. I’ve got 4 of them, all about 3 feet long or so.
So the bottom is flatter than the top, but it’s definitely not flat.
Assume the bottom is just as uneven as the top. What’s the issue sending it through the planer? Is it a safety issue or a efficiency issue?
I am definitely not skilled enough with a hand plane to get that accomplished, especially not on oak. Maybe I should start honing that skill though.
View MrUnix's profile
MrUnix
7050 posts in 2401 days
#5 posted 04-13-2017 07:33 PM
It’s a non-issue. Just take light cuts until you get them even, then flip and do the same.
Although – your comment:
makes me think that not having a planer might just make it a bit more difficult :)
Jangles
3 posts in 611 days
#6 posted 04-17-2017 01:49 PM
Yes, the not-having-a-planer issue is the next step. I’ve heard of a few woodworking shops that will charge you to plane a board. Not ideal, but should be much less expensive than buying one.
Thanks for the help!
View papadan's profile
papadan
3584 posts in 3571 days
#7 posted 04-17-2017 06:18 PM
You do need to plane the pieces flat, sanding would take forever. If you can’t afford to buy a planer, maybe look at a hand plane. properly set it would make short work of those boards.
