2 flute straight bit into endgrain
Forum topic by ScottKaye posted 04-13-2017 03:40 PM 632 views 0 times favorited 9 replies Add to Favorites Watch
View ScottKaye's profile
ScottKaye
681 posts in 2074 days
04-13-2017 03:40 PM
I’m looking into using a 1/2” – 2 flute straight bit to cut the mortises for the bed rail hardware I’m installing into the rails and posts of the bed I’m building for a friend. My question is what kind of a cut will I get using the 2 flute straight bit into the end grain of the rails (soft maple)? I suspect its a bad idea and will lead to wild tear out. (though I could be wrong!) Id rather not have to go out and buy a spiral down cut bit but is that really my only choice to get ‘crisp’ edges around the mortise?
thanks!
Scott
-- "Nothing happens until you build it"
9 replies so far
View CharlieK's profile
CharlieK
556 posts in 3914 days
#1 posted 04-13-2017 03:43 PM
Not sure. Do you have some scrap that you can make a few test cuts on?
-- Adjustable Height Workbench Plans http://www.Jack-Bench.com
View HokieKen's profile
HokieKen
6181 posts in 1259 days
#2 posted 04-13-2017 03:49 PM
You might consider cutting a saw kerf or scoring a knife wall around the mortise shoulder prior to doing the routing. That might be sufficient to leave a clean edge at the shoulders.
-- Kenny, SW VA, Go Hokies!!!
ScottKaye
#3 posted 04-13-2017 03:49 PM
I left the rails long so I could practice cutting the mortises. I’m cutting them by hand (so to speak) with a 2 1/4 hp Bosch EVS23 plunge router and the Bosch micro adjustable fence so I suppose I get to test the bit too :)
Scott.. Ill let everyone know how it turned out
ScottKaye
#4 posted 04-13-2017 03:51 PM
+1 @ Kenny. Good idea
View Rich's profile
Rich
3549 posts in 710 days
#5 posted 04-13-2017 07:20 PM
You could try using a drill to remove much of the waste, then use the router to clean up.
View AandCstyle's profile
AandCstyle
3154 posts in 2378 days
#6 posted 04-13-2017 08:33 PM
Hey, Scott, I have a Whiteside RU 5200 if you want to borrow it.
-- Art
View Andre's profile
Andre
2019 posts in 1927 days
#7 posted 04-14-2017 01:26 AM
I use mill ends on my Horizontal mortiser without any problems, just go in slow!
runswithscissors
2823 posts in 2146 days
#8 posted 04-14-2017 01:45 AM
I would think the spiral bit would work better, but I’d choose an up spiral. The down spiral will pack chips into the bottom of the mortise and bog it down. Unless you are planning on a through mortise?
View SawduztJunky's profile
SawduztJunky
71 posts in 1279 days
#9 posted 04-14-2017 04:12 AM
I have done a few, I had to hog out the bulk with the ½” straight bit, come behind with the MUCH cheaper ¼” DOWN SPIRAL bit. Why a down spiral? It tends to minimize surface blowout (a common and aggravating occurrence with maple) and leaves a decent looking ⅛” radius corner. Or a chisel and a hammer works pretty good if you need squared corners.
-- I don't think I'm ever more "aware" than I am right after I hit my thumb with a hammer. Questions about solid surface? Just ask. http://www.swiiitch.portfoliobox.net
