Squaring Irons w/out a grinder
« back to Hand Tools forum
Forum topic by MagicalMichael posted 04-12-2017 10:50 PM 656 views 0 times favorited 12 replies Add to Favorites Watch
View MagicalMichael's profile
MagicalMichael
117 posts in 694 days
04-12-2017 10:50 PM
Topic tags/keywords: plane irons sharpening squaring irons
I have a smoothing plane iron, 1 7/8” that was sharp but about 1 mm out of square. I have been trying to square it on a Washita stone with the Veritas jig. After more than an hour I have reduced the error to maybe .5 mm. I don’t own a grinder so that is not an option. Am I doing something wrong? What other options do I have?
Michael
-- michael
12 replies so far
View Andre's profile
Andre
2145 posts in 1984 days
#1 posted 04-12-2017 11:15 PM
Sandpaper on a flat surface? I use self adhesive 180 grit to flatten plane bottoms on a chunk of granite! Cast tablesaw top works also.
View Don W's profile
Don W
18992 posts in 2745 days
#2 posted 04-13-2017 12:56 AM
if the lat adjustment is enough to make it work, I’d just sharpen it back a little at a time.
View JayT's profile
JayT
5935 posts in 2389 days
#3 posted 04-13-2017 01:00 AM
File the edge square and then sharpen. That way you are taking off the bulk of the metal with the file instead of the stone.
View cicerojoe's profile
cicerojoe
64 posts in 3623 days
#4 posted 04-13-2017 02:47 AM
I agree course sand paper is your best bet. As course as what will work. I don’t think a file is harder than tool steel, but I could be wrong. I have tried files and they didn’t work for me. I would get it square then redo the bevel, then finish on your stone.
-- John from the Cherry Valley Studio in NY http://www.cvalleystudio.com
View bbasiaga's profile
bbasiaga
1240 posts in 2173 days
#5 posted 04-13-2017 02:52 AM
I’d think that .5mm is well within the lateral adjustment of most planes. Are you having an issue actually using the blade?
Brian
View BurlyBob's profile
BurlyBob
5937 posts in 2443 days
#6 posted 04-13-2017 03:05 AM
I had to do that very thing today on 2 plane irons. I used the exact method Andre suggested. It was time consuming but it worked just fine.
View Aj2's profile
Aj2
1813 posts in 1976 days
#7 posted 04-13-2017 03:09 AM
Michael your gonna have to change your name if you don’t figure this out.
It doesn’t sound like a problem
-- Aj
View HokieKen's profile
HokieKen
6636 posts in 1316 days
#8 posted 04-13-2017 12:04 PM
First, what DonW said. If that doesn’t work, then what Andre said :-)
-- Kenny, SW VA, Go Hokies!!!
View rwe2156's profile
rwe2156
3140 posts in 1658 days
#9 posted 04-13-2017 01:14 PM
Use of a jig and distributed pressure will bring .5mm back very easily.
I wouldn’t worry about it it will adjust out on the plane.
MagicalMichael
#10 posted 04-13-2017 01:31 PM
Yes, .5 mm is within the adjustment of my Primus plane. Maybe I’m just being obsessive about this. The original error – 1.0mm was not. Once I got started on it I wanted to get to perfection; this may not be a realistic goal for woodworking.
Michael
-- michael
HokieKen
#11 posted 04-13-2017 01:49 PM
Oh, it’s realistic to get it square. There’s a lot of unrealistic goals for wood but metal’s much more reliable ;-P It’s just a matter of whether or not the added work to get it square even though you really don’t have to is worth the effort to you.
MagicalMichael
#12 posted 04-13-2017 03:34 PM
On second thought, I am currently working on a new office, for myself and am down to 20 Birdseye Maple drawer fronts, so wanting my smoothing plane “perfect” wasn’t entirely irrational. In the end I accepted the 0.5 deviation and the plane is working very nicely. Thanks for all the suggestions, I do appreciate them.
Michael
BTW, I got my nick name while leading non-violence training in a maximum security prison.
-- michael
