Picture frame Glue up tip
Forum topic by Tim Dahn posted 10-30-2010 08:23 PM 2657 views 12 times favorited 20 replies Add to Favorites Watch
View Tim Dahn's profile
Tim Dahn
1577 posts in 3800 days
10-30-2010 08:23 PM
Topic tags/keywords: tip clamp
While reading yuri's post regarding clamping time the “memory vault door” opened slightly (you more seasoned LJ’s know of what I speak) and I remembered seeing this tip at the wood show in Chantilly Va last spring.
First of all: the credit for this goes to Bill Bush.
Just cut a paper grocery bag into 3” squares, put liberal amount of glue on both sides of your frame joint. I also always add a spline to my picture frames once the joint is dry for added strength.
put the two sides together and put them on the paper.
Press the two sides together tight and hold for a few seconds until you have glue squeeze out. Clean off the glue and let it dry, as the paper dries it shrinks pulling the joint tighter. It woorks for 3/4”-1” thick wood, if you want to glue up a thicker board just put a piece of paper bag on the top too.
Here are some pics of the frame I did using this paper bag clamp.
20 replies so far
View degoose's profile
degoose
7245 posts in 3590 days
#1 posted 10-30-2010 10:21 PM
Ok but where do I get paper grocery bags down under… great tip… now to look for paper grocery bags… all our bags are plastic or cloth…
View Dan'um Style's profile
Dan'um Style
14179 posts in 4218 days
#2 posted 10-30-2010 10:25 PM
way cool
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3342 days
#3 posted 10-30-2010 10:31 PM
Would brown wrapping paper do the same?
View rivergirl's profile
rivergirl
3201 posts in 3073 days
#4 posted 10-30-2010 10:50 PM
In the grocery store they might sell brown paper for wrapping? So you just glue up and wipe off the squeeze out and plunk it down on a brown paper bag? That’s it?
-- Homer : "Oh, and how is education supposed to make me feel smarter? Besides, every time I learn something new, it pushes some old stuff out of my brain."
View stefang's profile
stefang
16209 posts in 3569 days
#5 posted 10-30-2010 11:04 PM
The method you are showing us here Tim is basically the same as for using veneer tape along seams. Seem like aneasy way to clamp.
rivergirl
#6 posted 10-30-2010 11:06 PM
Hey I bet paper drywall tape might work?
Tim Dahn
#7 posted 10-30-2010 11:07 PM
degoose – PM me your address and I will mail you some.
lilredweldingrod – give it a try on some scrap and let us know, but I bet it works.
rivergirl – glue it up, plunk it down on the paper, squeeze it together while you position the two pieces then let it dry. I gave it a few minutes the wiped off the glue, you could also wait longer the scrape it off.
It’s that easy.
View Jim Bertelson's profile
Jim Bertelson
4256 posts in 3399 days
#8 posted 10-30-2010 11:28 PM
This is in the category of tricks. This I gotta try, even with some scrap wood. Favorited it.
On call, getting a tiny bit of woodworking done…..........
Jim
-- Jim, Anchorage Alaska
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3350 days
#9 posted 10-31-2010 03:32 AM
thank´s for sharing one of those “why didn´t I think of that”
after all we have seen paper schrink the hole life when it get wet
take care
Dennis
View Paul2274's profile
Paul2274
330 posts in 3347 days
#10 posted 10-31-2010 04:18 AM
Might have to try that one… not too sure though… had to check the calendar make sure it wasn’t April.
I will try though. Thanks.
Paul
35152 posts in 4635 days
#11 posted 10-31-2010 04:40 AM
Seems like a great tip. Thanks
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
24808 posts in 4086 days
#12 posted 11-18-2010 09:07 AM
I like the idea. Can’t see why it would not work.
View rance's profile
rance
4267 posts in 3395 days
#13 posted 11-18-2010 01:20 PM
Clever, Timbo. Thanks for posting.
degoose,
Brown paper bags are made of Kraft Paper. You might try the butcher in the back of the store. They (used to) use it for wrapping meat. Deer hunters probably still get theirs wrapped in it. Or you can sometimes find it at craft stores like Michael’s. HTH.
rivergirl
#14 posted 11-18-2010 02:05 PM
Just can’t use the paper that is waxed on wide side. It won’t shrink. :)
View Howie's profile
Howie
2656 posts in 3158 days
#15 posted 11-18-2010 02:08 PM
That’s a handy tip. Thanks for posting it.
-- Life is good.
