Coping Sleds for Router Tables
Forum topic by Dub posted 291 days ago 479 views 0 times favorited 2 replies Add to Favorites
View Dub's profile
Dub
2 posts in 292 days
291 days ago
First real post so, I appologize if it’s in the wrong forum.
I’m putting together a sled for cutting stiles on my router table. Using a 12”x16” phenolic base 1/4” thick. Kreg’s 3/4” rail w/adjustable set screws to eliminate slop in the channel. 5/4 stock backing that has a single toggle clamp and an old plastic handle from a bench plane. 3/4 high density plastic that will be extended to the bit for support and to prevent tearout. Extra fine self adhesive sandpaper for under the work piece and an adjustable knob from the same plane for the front.
So my questions are: Overkill?, Justright?, or Do you think I’m missing something major? Also, do you know a good supplier for the high density plastic for 13” or longer lengths.
Thanks and I look forward to posting more.
Dub
-- Dub
View che's profile
che
123 posts in 554 days
291 days ago
I get most of my plastic (and metal and stainless hardware and…....) from McMaster-Carr www.mcmaster.com
I just got my first rail / style set for Christmas but since I haven’t put together a table and I haven’t had an urgent need to try and hurt myself running it hand held so they are still in the protective plastic.
I’ve seen plenty of people route stiles with a single piece of wood (to act as a backer) running on along a fence. I’m a minimalist so anything more than that is overkill in my opinion.
-- Che.
View GaryK's profile
GaryK
8541 posts in 516 days
291 days ago
McMaster is a good place to find a lot of things.
Bookmark And Share This Page
