My sliding/ removable outfeed table
Forum topic by Bob #2 posted 10-30-2010 06:16 PM 5379 views 4 times favorited 11 replies Add to Favorites Watch
3809 posts in 3929 days
10-30-2010 06:16 PM
Topic tags/keywords: jig tip outfeed table
The table is just a hinged piece of MDF attached to a 1” rod that is bolted to the table on my saw.
I have a PDF plan of this ( not mine ) for the asking. (must be at work on one of my other 3 computers Grrr!)
The real advantage of this system is the saving of space when it’s not in use. I can either fold it up above the saw as shown to remove it in a few seconds and stow it under the saw. It slides back and forth across the bar to catch the kerf on what ever I am cutting and has carried many a sheet of 3/4” MDF without a problem.
Here’s a shot of the outfeed removed . This gives me ample room to work on my bench when I’m not using the table saw.
In this shot your can see the casters on the bottom that allow me to slide the table back and forth with one hand.
When I set up my shop I made sure that may table saw was at the same height as my work bench and I modified my little 6” jointer to be the same height as well.These simple adjustments saved me tons of floor space and allowed me room to cut up a 10 foot strip on my table saw without running into any obstacles.
There is an 8 foot piece of MDF on the saw to show that the surfaces all line up with each other.
Also note that I have 2 cupboards under the runoff on the saw that holds my push sticks and extra blades etc.
The iron bar hanging down off the fence on the left side is used to hold the lead edge of my plywood sheets while I turn them up on the cutting surface.
This shot just shows the two bolts used to lock the table to the table on the bar when I am cutting stock. They have no fasteners and just sit in the slots by friction so they are easily removed.
I made this little table back in 2000 and have been using it ever since.
11 replies so far
View Abbott's profile
Abbott
2570 posts in 3211 days
#1 posted 10-30-2010 06:27 PM
That’s a heck of a good idea Bob.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
View jusfine's profile
jusfine
2422 posts in 2833 days
#2 posted 10-30-2010 06:30 PM
Great concept!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View prez's profile
prez
375 posts in 3318 days
#3 posted 10-30-2010 08:10 PM
I like it!! I’ve been looking for something like this….you say you have the plans?? Can you email me a copy? I’d really appreciate it…tks
-- George..." I love the smell of a workshop in the morning!"
View degoose's profile
degoose
7228 posts in 3262 days
#4 posted 10-30-2010 10:11 PM
Good looking accessory to the TS
#5 posted 10-31-2010 12:31 AM
Prez, if you PM me with your e-mail I will try to run the file down at work. I thought it was on this box when I started typing.
Thanks for the comments fellas and for having a look .
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3014 days
#6 posted 10-31-2010 05:03 AM
Bob,
That is handy and compact. Great idea. Rand
View laverned's profile
laverned
6 posts in 3030 days
#7 posted 11-11-2010 05:04 PM
Great idea for saving space & multi use of equipment. Would love to have the plans if you can find them. E-mail to mr_mac43@msn.com. mark subject table so I won’t delete from junk e mail. thanks
View hscott's profile
hscott
1 post in 2397 days
#8 posted 08-02-2011 03:32 PM
Would you please email me a copy of your plans.
scottcarson at austin dot rr dot com
thks
View Lynden's profile
Lynden
74 posts in 3054 days
#9 posted 09-01-2011 07:49 AM
I like your design and your method for moving the table across the width of the table saw. My outfeed table is similar to yours, only a little wider (28”) and longer. Mine moves back and forth using a series of holes in the rear rail of the saw. When moved all the way to the left, the table serves as an outfeed for my router table, which is mounted in the left extension wing of the saw. When moved all the way to the right, the table and the right extension wing of the saw can be used together as a work table. When not in use, I remove the table, fold the legs and lay it on top of the table saw.
laverned
#10 posted 03-11-2015 02:59 PM
Could you please send me a set of the plans. I think this is a great space saving and needed (by me anyway) accessory for my table saw and small shop. Thks
#11 posted 03-11-2015 05:09 PM
I used the plan in this issue of shop notes.
