general rules
Forum topic by pommy posted 10-30-2010 11:32 AM 879 views 0 times favorited 4 replies Add to Favorites Watch
View pommy's profile
1697 posts in 3622 days
10-30-2010 11:32 AM
Topic tags/keywords: resource question pine
Hi guys
Is there a general rule one should follow when hanging doors i have 30+ to do for a client
-- cut it saw it scrap it SKPE: ANDREW.CARTER69
View Sawkerf's profile
1730 posts in 2999 days
#1 posted 10-30-2010 02:53 PM
For prehung doors, I generally check the plumb of the hinge side framing, measure the width of the RO, and install some shim spacers on the hinge side (if necessary) to center the door. Then, I remove the door and stop, stand the jambset in the rough opening, and use a 6’ level on the hinge barrels to get them dead-on plumb.
Once the hinge barrels are plumb, I reinstall the door and work my way across the top and down the latch side using shims to get the desired gap between the door and the jambset.
When the jambset is nailed off and solid, I put in the lockset, latch, and striker plate, make sure the door doesn’t swing on it’s own, then reinstall the stop. I like to use a folded business card to set the gap between the door and the stop.
This process sounds a bit complicated, but after 3-4 doors, it goes pretty fast. The trick is to get the hinge barrels plumb from the get-go so the door doesn’t swing on it’s own when you’re done.
-- Adversity doesn't build reveals it.
35111 posts in 4331 days
#2 posted 10-30-2010 03:11 PM
I would think that putting the hinges on the opposite side of the door from the knob would be a good rule.
Good luck. buddy.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware soon moving to Virginia †
View Gene Howe's profile
Gene Howe
10250 posts in 3359 days
#3 posted 10-30-2010 03:20 PM
I tried that, and it works!
#4 posted 10-30-2010 03:24 PM
thanks Gene
