Bearings for Delta 28-276 bandsaw
Forum topic by beamrider posted 10-30-2010 02:26 AM 1852 views 0 times favorited 7 replies Add to Favorites Watch
View beamrider's profile
beamrider
24 posts in 3228 days
10-30-2010 02:26 AM
If this is posted in the wrong place, I apologize, I wasnt sure where to put it.
I’m thinking the bearings on the top wheel need replaced, the wheel doesnt seem to spin freely, at least not to me. The bottom wheel, if the blade and belt are removed, will spin until the momentum dies. The top wheel, on the other hand, seems to stop a LOT quicker. Not to mention that the bearings seem to “click” every second or two, and make what I’d call a ” soft grinding WHIRRRRRR” sound. So with that in mind, I’m wondering if anyone has
any suggestions as to some good sealed bearings for this poor wheel. Also, if anyone near Columbus Ohio has any suggestions for a place to get both wheels trued and balanced, I’d be happy to hear those as well. I figure if I’m going to be pulling the wheels off anyway, I might as well get it all done at once.
Thanks!
7 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 3088 days
#1 posted 10-30-2010 06:35 AM
The age of the machine would be interesting data here, beamrider.
Bearings are commonly found in the yellow pages (remember them?) under, I think, “power transmission.” These places usually have a front counter and an old guy name Emil who knows every part number by heart. He’s the one to ask, and make sure he understands that you’re not shopping price.
The clicking and slow spin are sure signs it’s time to replace the bearings. If the machine has a lot of miles, might as well do the lower wheel too. If, however, it’s relatively new and hasn’t been rode hard and put away wet, you may just be dealing with an early failure up top.
As for balance, I’d check the web to see if there is a how-to. In all the bandsaws I’ve owned, I’ve never felt like this was ever an issue.
I can’t remember ever replacing a wheel bearing in a BS but I keep a spare set of guide and backing bearings on hand for both of mine. As long as you’re buying bearings, you might consider this. When they fail they are noisy and annoying, and relatively easy to replace.
Let’s hear from some more LJs…
View popmandude's profile
popmandude
109 posts in 3258 days
#2 posted 10-30-2010 11:48 AM
For the bearings call accurate bearings, ask for Lynn. Tell her you are from owwm.org.(old wood working machines). I think folks from that website get a group discount. Lynn is quite knowlagable, an very helpful. Have all your info in front of you because wood workers keep her quite busy.
Good luck
Randy
View barryvabeach's profile
barryvabeach
159 posts in 3281 days
#3 posted 10-30-2010 02:38 PM
+1 on Lynn. For balancing, the ultimate is in Wiki pages at OWWM. I used duct tape and loose change, but otherwise the same.
View lew's profile
lew
12500 posts in 3993 days
#4 posted 10-30-2010 03:34 PM
Check at an electric motor repair shop. They have a very large selection of bearings.
beamrider
#5 posted 10-30-2010 05:03 PM
The sad thing is, this machine is not quite a year old, and hasnt seen much mileage at all. I’ve never been able to get everything to fall into place with it, and it has sat in a corner, with nothing thrown at it but mean looks once in a while. So I’m finally ripping it apart piece by piece to get it working the way it should.
View MedicKen's profile
MedicKen
1615 posts in 3700 days
#6 posted 10-30-2010 05:06 PM
+2 fro Lynne at accurate
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3344 days
#7 posted 10-30-2010 05:22 PM
For replacement bearings of almost any kind, try Applied.com. The full name is Applied Technologies. If they don’t have it, no one does.
As for balancing what ever you are trying to balance. try heavy copper wire. As soon as you get the balance, secure it with epoxy.
