Removing a broken bolt.
« back to Coffee Lounge forum
Forum topic by mahdee posted 04-11-2017 01:13 AM 1098 views 0 times favorited 19 replies Add to Favorites Watch
View mahdee's profile
mahdee
3883 posts in 1761 days
04-11-2017 01:13 AM
Topic tags/keywords: jig resource question
Hello guys and gals. So, I have a lawnmower (used twice) and the bolt that held the blade broke off from about 1/4 inside the shaft. Thankfully the blade didn’t come flying at me. Can anyone guide me as to how I should go about getting the bolt out?
Thanks in advance.
-- earthartandfoods.com
19 replies so far
View lumberdog's profile
lumberdog
245 posts in 3261 days
#1 posted 04-11-2017 01:27 AM
I believe the best and safest thing to do would be to take the engine apart and replace the shaft, it isn’t a hard job, just time consuming.
-- Lumberdog.. Morley, Michigan
View diverlloyd's profile
diverlloyd
2727 posts in 1851 days
#2 posted 04-11-2017 01:33 AM
If it’s a push mower set on some saw horses and clamp it to them. Then use a easy out extractor. If it a rider the same thing but remove the deck.
mahdee
#3 posted 04-11-2017 01:34 AM
Thanks. Just the thought of taking it all apart and as you mentioned the time involved, is not worth $120.
mahdee
#4 posted 04-11-2017 01:36 AM
diverlloyd, will the extractor go inside the hole? I suppose if I use a small one it will.
diverlloyd
#5 posted 04-11-2017 01:45 AM
Yes they come with a drill bit that is the proper size most of the time. So you center punch the broken bolt and then drill it. Then use the easy out. The only issue is what grade of bolt was it and if it was left handed threads. I would assume it’s a low grade bolt so the easy out should work. Does the blade mounting tap have two pins for aligning the blade and keeping it from spinning if so you may have more issues then just a broken bolt. How did the bolt brake?
mahdee
#6 posted 04-11-2017 01:54 AM
Probably made in china bolt. First time it just fell out with the bolt and all, second time it just broke off while I was mowing without hitting anything. It doesn’t have the plate nor did it come with a washer; walmart crap.
diverlloyd
#7 posted 04-11-2017 02:07 AM
Yes Wally World is junk. Sound pretty returnable if you just purchased it and ran it twice. But if you keep it you may need to put a good quality lock washer on it and/or some red loc tite.
View BurlyBob's profile
BurlyBob
5487 posts in 2259 days
#8 posted 04-11-2017 02:54 AM
mahdee, may I suggest you replace it with a Honda. I bought one in the early 90’s. I’m going to fire it up again tomorrow. It’s kinda like that pink rabbit with the bass drum on TV. It just keeps on running. After all these years I’m pretty sure I’ve gotten my money’s worth out of it.
View Rich's profile
Rich
2797 posts in 583 days
#9 posted 04-11-2017 04:10 AM
You’ve used it twice, and there’s no warranty?
-- No matter how much you push the envelope, it'll still be stationery.
mahdee
#10 posted 04-11-2017 11:14 AM
Thanks a million guys. I am certainly going to look for a Honda Bob. diverlloyd, Thanks for all the instructions. Rich, I used it once last year and then this spring. I think they have a 90 days warranty. I have a riding one and two push ones; to maintain about 8 acres.
View hairy's profile
hairy
2701 posts in 3526 days
#11 posted 04-11-2017 11:28 AM
If you go the easy out route, drill the hole with a left handed drill bit. That can sometimes get the bolt to back out.
-- My reality check bounced...
mahdee
#12 posted 04-11-2017 12:04 PM
hairy, Good one. Thanks.
diverlloyd
#13 posted 04-11-2017 12:26 PM
I second the Honda engine and a older Briggs. I got 12 years out of the last Briggs.
View oldsailor59's profile
oldsailor59
51 posts in 424 days
#14 posted 04-11-2017 01:31 PM
a Honda would be a nice one. some Honda lawn mowers are made in the next county. their property has 5 or 6 acres of lawn grass. almost every time I drive past, there is someone riding or pushing a mower for endurance testing.
-- Scott just a tired old sailor glad to be home from the sea
mahdee
#15 posted 04-11-2017 02:09 PM
Scott, I wish they were here doing my lawn for endurance test.
