Blade spun on unisaw.. repaired
Forum topic by Jimintomahawak posted 04-11-2017 12:24 AM 393 views 0 times favorited 1 reply Add to Favorites Watch
View Jimintomahawak's profile
65 posts in 411 days
04-11-2017 12:24 AM
I bought a used UniSaw and took most of it apart to clean it up but missed seeing a blade had spun on arbor. I know the blade that came with it was garbage but everything pretty much checked out ok. When I was aligning blade to miter slot I normally setup a dial indicator to check runout. Found nearly .03” on a brand new blade. Uh oh…
Arbor flange had about .0025” runout on the face. ⅝ diameter had less than .0005”. To make a long story short I was able to rig up a little grinder using than flexible shaft attachment for my die grinder. It’s ugly but it worked. Arbor flange face has less than .0003 runout now. Finish is u
gly but it’s accurate.
Drilled through 2 scraps of ¾ plywood and a 2×4 to mount the grinder. I shifted the 2×4 to get wheel perdicular to arbor flange.
Next I clamped a nut to table to act as an adjuster. I figured I couldn’t control the infeed by hand..
Touched off and adjusted angle for square and started grinding.
-- Laziness drives creative thinking...
1 reply so far
View Kelly's profile
1951 posts in 2880 days
#1 posted 04-11-2017 04:16 AM
Nice job. I’ll tuck that idea away, in case I ever spin a blade on mine.
