Using Planes Without Bench
« back to Hand Tools forum
Forum topic by mision56 posted 04-10-2017 09:22 PM 1304 views 0 times favorited 20 replies Add to Favorites Watch
View mision56's profile
mision56
48 posts in 819 days
04-10-2017 09:22 PM
Hi All,
I have been experiemnting more and more with hand tools but lack the space for a large stable/heavy bench to serve as an anchor for this kind of work. All of my working benches are by necesity on wheels and are lightweight and I’m curious if anyone out there has good, small footprint/portable options for setting up a vice and being able to hold down pieces while planing/chiseling/scraping?
I am lucky enough to have a cabinet saw, so I do on occasion use that as hold down area for planing, but it’s obviously less than ideal.
Any plans/tips are appreciated.
20 replies so far
View JayCee123's profile
JayCee123
200 posts in 1004 days
#1 posted 04-10-2017 09:31 PM
A vice on at the work top is a good start. Try attaching two angles to the mobile table top. Roll the table against a wall and run a couple of screws thru the angles and into the wall studs. When ya need to roll the benches “back” just take out the two screws and roll away.
View TheFridge's profile
TheFridge
10818 posts in 1726 days
#2 posted 04-10-2017 09:35 PM
Solid outfeed table table?
Smitty_Cabinetshop
15822 posts in 2858 days
#3 posted 04-10-2017 09:38 PM
I second the suggestion of finding a way to run a table against a wall (or even into a corner) when working with hand tools. Several LJs have effectively used a Workmate for planing… they didn’t like it, but it worked. Necessity is the mother of invention; you’ll come up with something that works OR find a way to build and house a suitable bench.
View gargey's profile
gargey
1013 posts in 1015 days
#4 posted 04-10-2017 09:44 PM
Hard to get something to act like a workbench without being a workbench…
View Texcaster's profile
Texcaster
1286 posts in 1913 days
#5 posted 04-10-2017 09:45 PM
I’m going to build a quickie bench for a mate’s son, using this hardware. The bench is a morning’s work, butt joints and batten screws for everything. You could of course make it nicer. I took this bench to the Ukulele class I taught and the participants gave it heaps, no worse for the wear.
http://lumberjocks.com/projects/92424
bench link
http://www.anzlf.com/viewtopic.php?f=24&t=5266
Uke Shed bench
http://lumberjocks.com/Texcaster/blog/95858
-- Mama calls me Texcaster but my real name is Mr. Earl.
View MikeUT's profile
MikeUT
189 posts in 1599 days
#6 posted 04-10-2017 09:57 PM
Chris Schwarz wrote an article in popular woodworking called ‘Milkman’s Workbench’ that could be a good solution. Search that term in the project section and you’ll find a few clever variations. I made a version of it when I saw it and found it pretty useful. I didn’t made the clamp and vise sections out of threaded wood, I used a 3/4” threaded rod and made a wood handle I attached to the end. It’s not a perfect solution but it works good enough to keep you over until you decide to make a dedicated space for using your hand tools. Here is the article by Chris.
http://www.popularwoodworking.com/workbenches/schwarz-workbenches/the-milkmans-workbench-in-use
View bandit571's profile
bandit571
22016 posts in 2923 days
#7 posted 04-10-2017 10:30 PM
Maybe….have a piece of plywood/mdf/whatever. Add a cleat under it, to keep it from sliding across the saw’s top. You can add a cleat at the other end, thinner than the stock you would be using a plane on. You can clamp this plane stop to the saw’s top, with enough overhang out to the side to allow you to do a bit of hand plane work.
When not needed, you can just hang it up on the wall.
If you need a different cleat/stop to hold a piece still, you can just add it to the plane stop. It can hold most jigs used for a plane, or it can be rather empty. How wide and how long to make this is up to you. Maybe add a cleat to attach the plane stop to the saw’s fence, using a couple clamps?
At one time, all I had to work with was a back porch railing or two. Worked for a lot of years, just using the top of an old contractor’s saw, that was also my shop’s main saw.
View LDO2802's profile
LDO2802
167 posts in 670 days
#8 posted 04-10-2017 11:04 PM
Maybe a bit in left field, but you could take 2×4’s and make a square, then put holes in the sides that accommodate clamps. Put it on the ground, clamp the workpiece in and then put your knees on the edge and plane away from you. (Trying to think outside the box here) Get it? LOL
View canadianchips's profile
canadianchips
2616 posts in 3237 days
#9 posted 04-10-2017 11:27 PM
Here is a portable saw horse vise that works
Wont break the bank building it.
Doesnt take up a lot of room
View Dan Wolfgang's profile
Dan Wolfgang
176 posts in 1047 days
#10 posted 04-11-2017 01:03 AM
Finding a wall to plane or chisel in to will go a long way towards giving you a stable place to work, as others have said. My experience with a lightweight bench against a wall has still been quite unsatisfactory, however. I’ve found that vigorous planing, chiseling, and sawing would rock the lightweight work surface around, and between seeing a little movement and knocking against the wall I was frustrated!
View Just_Iain's profile
Just_Iain
293 posts in 656 days
#11 posted 04-11-2017 03:56 PM
How about some 4×4 or as appropriate material under your mobile working benches (to lift wheels off the ground) with some sand bags to add mass? Would that be an option?
-- For those about to die, remember your bicycle helmet!
View waho6o9's profile
waho6o9
8539 posts in 2816 days
#12 posted 04-11-2017 04:04 PM
Nice!
canadianchips
#13 posted 04-11-2017 04:26 PM
waho6o9. This is not mine ! This is something I want to build . I just thought it would be very useful out of the shop
View JayT's profile
JayT
6010 posts in 2451 days
#14 posted 04-11-2017 04:40 PM
- canadianchips
That looks familiar for some reason. ;-)
-- In theory, there is no difference between theory and practice. In practice, there is.
Smitty_Cabinetshop
#15 posted 04-11-2017 04:49 PM
And I was looking at a rather crazy vise / clamp doohickey that’s in my shop and thinking, “Hey, it just might work as an end vise on my saw bench!” Great ideas never die, JayT.
