I have two Cherry Crotches and would like Ideas
Forum topic by CherryO posted 04-10-2017 01:58 AM 1252 views 0 times favorited 16 replies Add to Favorites Watch
View CherryO's profile
CherryO
25 posts in 735 days
04-10-2017 01:58 AM
I felled a very large diseased Cherry tree that split into four trunks and ended up with two crotches I’d like to do something with. I do not turn wood so that is out, but was thinking maybe an interesting cutting board. I am new so excuse anything obvious I am leaving out. first one is about 14” long and 10 inches deep and the second one is 23 inches long and 14 inches deep. see the pics. Thanks.
Pic1
Pic2
16 replies so far
View BurlyBob's profile
BurlyBob
5858 posts in 2352 days
#1 posted 04-10-2017 02:07 AM
If you can figure out how to get a few vertical slices. You might be able to bookmatch some really fantastic boards.
View JayCee123's profile
JayCee123
200 posts in 851 days
#2 posted 04-10-2017 01:46 PM
Do you have access to someone with a large bandsaw capable of slicing thru those chunks ? If it were me I’d be slicing and attaching to plywood and they’d become a panel in a door or lid.
CherryO
#3 posted 04-11-2017 12:55 AM
Thanks guys for the responses!
Bob, do you recommend a thickness to do the bookmatching? Im thinking of some type of coffee table top but heard cupping can be a problem.
JayC, my bandsaw has about a 13” resaw capacity but the table seems to small to handle either of these two pieces. Any recommendations on building some type of auxiliary table to handle these beasts? I have seen some homemade fences that might handle the job but still worried about it tipping off. And curious what lid would you use this for?
View mahdee's profile
mahdee
3948 posts in 1854 days
#4 posted 04-11-2017 01:31 AM
Use a chain saw to rough cut it. I normally put the crotch opposite of where the two branches split on a wood splitter and get natural crack in half. Once that is done clean the waste with a chainsaw, band saw it to shape and run it over the joiner to flatten one side and then through planer. I do this with the crotches when I am cutting firewood. If you are good at chainsawing, use it instead of splitter.
-- earthartandfoods.com
BurlyBob
#5 posted 04-11-2017 02:58 AM
Honestly, no! I’ve only resawn a couple of pieces of kiln dried boards with crotch grain. The results were amazing, truly stunning grain. I can only imagine what you might find in those pieces. I hope you find something awesome.
CherryO
#6 posted 04-12-2017 12:00 AM
mahdee, having a hard time envisioning how to do what you recommend. So if I am looking at the crotch and the V is facing me, are you saying split/saw it from the bottom of the V so the split goes across, creating two Vs?
BBob, thanks I am very excited on opening them up, they have been sitting in by yard for 2 years!!
JayCee123
#7 posted 04-12-2017 01:09 AM
CherryO-
Your last question is the easiest to answer … a beautiful jewelry box, the cherry crotch would be a good start
Your first question – You may have to rough cut them down to size before hitting the bandsaw.
Check the web … there are many ideas about building auxiliary table tops for your bandsaw along with a carriage to hold the work piece and guide it thru the blade. Then use your hand planes or a drum sander to get toward your finish surface. I wouldn’t use a planer on this material. With the grain being extremely non-directional and would probably self destruct in the planer.
View RobDubs's profile
RobDubs
39 posts in 545 days
#8 posted 04-12-2017 01:11 AM
.....that can be turned into a lot of spoons.
mahdee
#9 posted 04-12-2017 01:57 AM
Yes sir, two V’s. I can send you some picture tomorrow if needed. The wild grain fans out of the crotch into the two limbs.
View WDHLT15's profile
WDHLT15
1764 posts in 2562 days
#10 posted 04-13-2017 12:35 AM
Cherry crotches are bad to crack and split. I have had poor luck with them, but maybe your cherry will behave better.
CherryO
#11 posted 04-13-2017 12:42 AM
- RobNPHX
Ah if I only had a lathe, or more accurately, room for a lathe
CherryO
#12 posted 04-13-2017 12:47 AM
Yes sir, two V s. I can send you some picture tomorrow if needed. The wild grain fans out of the crotch into the two limbs.
- mahdee
Sure please send! I need to start working on an auxiliary table for the BS, but in the meantime I’d like to check out.
CherryO
#13 posted 04-13-2017 12:48 AM
- WDHLT15
I think you are right, I split a bunch of smaller ones when I split the limb wood, all over the place.
CherryO
#14 posted 04-13-2017 12:50 AM
CherryO-
Check the web … there are many ideas about building auxiliary table tops for your bandsaw along with a carriage to hold the work piece and guide it thru the blade. Then use your hand planes or a drum sander to get toward your finish surface. I wouldn t use a planer on this material. With the grain being extremely non-directional and would probably self destruct in the planer.
- JayCee123
Thank you for this info! Funny I had been looking at all types of sites on resawing but never saw one for a bigger table. Will look into it. Great point about not using a planer, could be a disaster.
mahdee
#15 posted 04-14-2017 01:32 AM
Sorry, there will not be a disaster running it through the planer.
