Veneer treatment, giving it flexibility
Forum topic by VladimirIvanovich posted 04-09-2017 02:12 PM 477 views 0 times favorited 4 replies Add to Favorites Watch
View VladimirIvanovich's profile
VladimirIvanovich
2 posts in 561 days
04-09-2017 02:12 PM
Topic tags/keywords: veneer
Hello. Does anybody know how to treat 0.55 mm veneer for giving it flexibility and durability for making lamp shades? I’ll be very grateful for answer! Image for example:
View splintergroup's profile
splintergroup
2310 posts in 1370 days
#1 posted 04-09-2017 03:07 PM
Many of the veneer treatments with propylene glycol make the wood very flexible. These treatments are used to flatten burl veneers before pressing, they stay “wet” longer than using just water.
View papadan's profile
papadan
3584 posts in 3516 days
#2 posted 04-09-2017 03:55 PM
I’ve heard of using glycerin to soften veneer for tight bends, but I don’t know the actual process.
VladimirIvanovich
2 posts in 561 days
#3 posted 04-09-2017 03:58 PM
- splintergroup
Thank you, but it is not that i really meant. Temporary softening is not what i want. I’m seeking for some treatment technique that gives veneer permanent flexibility. Moreover, i think it will crack over time in untreated state. And it’s fairly difficult to treat it after forming.
View shipwright's profile (online now)
shipwright
8086 posts in 2945 days
#4 posted 04-10-2017 12:57 AM
I haven’t done specifically what you are referring to but I have a lot of experience with veneer and a lot with S1 epoxy sealer from System Three. I just bet that if you gave the veneer a couple of coats each side, you would have about what you need. S1 is a very thin epoxy that penetrates well and adds a lot of strength to the fibre. You would have to experiment with coating before or after forming but if I were trying this project I think it would be my first choice.
