Finishing with Watco Oil
Forum topic by jackthelab posted 04-09-2017 11:16 AM 436 views 0 times favorited 3 replies Add to Favorites Watch
View jackthelab's profile
313 posts in 2626 days
04-09-2017 11:16 AM
I have a completed kitchen island top made out of walnut. I finished it the Natural Watco oil finish. I was wondering after this has set for a while, can I put a coat of poly over this to help finalize the sealing of the wood? Thanks in advance for any input.
-- Dave in Minnesota - If it ain't broke, improve it!
3 replies so far
View JayT's profile
5543 posts in 2144 days
#1 posted 04-09-2017 11:45 AM
Yes, once the Watco is fully cured, you can use a poly top coat. The Watco Danish Oil is a slow curing finish, so be sure to give it enough time. If you only used one coat, then a few days is probably enough. If you want to be even more sure of good adhesion, you could put a coat of shellac over the Watco before moving to poly.
View Gene Howe's profile
Gene Howe
10253 posts in 3361 days
#2 posted 04-09-2017 12:50 PM
You should have no problems at all. Just use oil based poly.
Watco mixed with poly makes a good wipe on finish. So, the two are compatible at any stage.
View OSU55's profile
1569 posts in 1922 days
#3 posted 04-10-2017 09:52 PM
Yes no problem. Here is some info you may find useful next time.
