Table Saw Ripping Poor Cuts (PLEASE HELP)
Forum topic by Brett Lowing posted 10-28-2010 01:45 AM 1780 views 0 times favorited 21 replies Add to Favorites Watch
View Brett Lowing's profile
Brett Lowing
23 posts in 2638 days
10-28-2010 01:45 AM
I have a Ridgid 10 in. CAST IRON TABLE SAW TS3650 and have tried both of these blades:
Diablo 10 in. x 24 Tooth Carbide Circular Saw Blade
Diablo 10 in. x 40 Tooth Carbide Circular Saw Blade
with the same results.
I have spent hours making sure the table saw has been set up precisely and have minimized the damage to the wood to the picture shown.
PLEASE HELP!!!
Am I missing something?
-- "Choose a job you love, and you will never have to work a day in your life." - Confucius
21 replies so far
View Walt's profile
Walt
245 posts in 2708 days
#1 posted 10-28-2010 01:51 AM
Brett
I can’t view any picture. What is the basic problem? Burning of the wood, tear out or inaccuracy of the line.
The 24 in blade is more for ripping and the 40 can be either a ripping , cross cut or combination blade
The speed that you move your stock also makes a difference.
-- Walt Wilmington Delaware, http://waltlumley@yahoo.com
View Howie's profile
Howie
2656 posts in 2792 days
#2 posted 10-28-2010 01:53 AM
Where is the picture and just what is the problem?
I have a 3650
-- Life is good.
Brett Lowing
#3 posted 10-28-2010 01:54 AM
Here’s the image. It’s showing the blade arc.
Brett Lowing
#4 posted 10-28-2010 02:04 AM
It’s the front edge of the blade leaving the damage when I rip and I can’t seem to eliminate it.
View TheDane's profile
TheDane
5348 posts in 3532 days
#5 posted 10-28-2010 02:49 AM
Maybe the blade isn’t parallel to the fence?
Brett Lowing
#6 posted 10-28-2010 03:01 AM
What kind of tolerances are there for it to be considered parallel? I used a combination-square to set everything parallel. Started with the blade to the table, then the fence to the table, then checked the fence to the blade. It’s pretty dang close to perfect if not perfect.
View PurpLev's profile
PurpLev
8534 posts in 3518 days
#7 posted 10-28-2010 03:02 AM
can you detail what you mean by ”I have spent hours making sure the table saw has been set up precisely”?
I can only assume you have tuned the blade parallel to the miter gauge, and the fence parallel to the miter gauge as well so that everything is perfectly aligned? if not – that’s a good change to be the cause
did you check for arbor runout? if it’s too much it can cause the blade to not run true and wobble just enough to cause what you’re seeing
did you check for blade deflection? if the blade is not flat it’ll wobble and can create aftereffects such as you are seeing
are these thin kerf blades? if so, you might want to try using a blade stiffener.
thats all I can think of at the moment.
Brett Lowing
#8 posted 10-28-2010 03:29 AM
I’ve tuned the blade parallel to the miter gauge, and the fence parallel to the miter gauge as well so that everything is perfectly aligned. (Just took me a while to get perfect)
I don’t have a dial indicator to properly check for arbor runout. I set my combination-square against the front of the blade and turned it and notice a very minor difference when turning. I feel like this may be my issue. Can you explain more on this? Should I get a dial indicator?
I laid a straight edge against all the different blades I’ve tried and they are all flat.
The blades are Freud Diablo Brand from Home Depot (laser cut thin kerf design) But the result is the same from all of them, so it’s not the blades.
View GaryL's profile
GaryL
1099 posts in 2700 days
#9 posted 10-28-2010 03:33 AM
In my jobsite saw, I get the same cut with Diablo blades. I think it is just a product quality issue. I consider Diablos as throw away blades. But I do know that some LJ’s get satisfactory results with their Diablos. Try upgrading to a Freud Industrial and see how that does. I’m assuming this is not your cabinet shop saw.
If you have a higher quality blade in your shop or perhaps can borrow one, throw it on and see how it does.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
Brett Lowing
#10 posted 10-28-2010 03:39 AM
I’ve been using those blades for about 4 years now with no problems as my cabinet shop saw. I’ve recently moved my equipment across the country and probably incurred some misalignment. But I would definitely consider purchasing a high quality blade.
View ajosephg's profile
ajosephg
1880 posts in 3430 days
#11 posted 10-28-2010 03:39 AM
In order to get cuts to the perfection you are looking for you need to get the blade/fence alignment to within 0.002 from front to back. The best way to do it is with a dial indicator and a jig to slide it from front to back in the miter slot. I have a paper that explains it in detail. If you want it, send me a PM.
-- Joe
GaryL
#12 posted 10-28-2010 03:42 AM
Maybe go through the whole saw, trunnions, base, motor mount, etc to make sure nothing has worked loose during transport.
Brett Lowing
#13 posted 10-28-2010 03:43 AM
That’s some good advice! I sent you my e-mail address.
Brett Lowing
#14 posted 10-28-2010 03:52 AM
I did go through and make sure everything was tight. Thanks though!
Brett Lowing
#15 posted 10-28-2010 03:55 AM
I’m going to purchase a dial indicator and go from there. Hopefully I can get this thing figured out! Thanks for all the help! I’ll let you know what comes of it.
