Foodsafe stain/oil
Forum topic by Boon posted 661 days ago 1985 views 1 time favorited 11 replies Add to Favorites Watch
View Boon's profile
Boon
65 posts in 716 days
661 days ago
Ok, i bought some food safe stain for salad bowls and things of that nature, but i am curious if after i use this oil on a project if i can cover it in polyurethane and it will keep the great finish?
-- www.jonboon.info - more crap coming soon!
View WoodworkersResource's profile
WoodworkersResource
33 posts in 869 days
660 days ago
It’s been my experience that even as tough as poly is, it will still start to chip and peal after repeated use. I would just stick with the oil. After a few washings, when your bowls start to look faded and worn, simply wipe some more oil on them and let them cure. You’ll know it’s cured completely when you can’t smell any oil on the bowls.
Hope this helps.
-- Craig, www.WoodworkersResource.com (Where Information meets Inspiration)
View Boon's profile
Boon
660 days ago
i should have been more explanatory. i dont need to wash the things i use the oil on, its just more convenient for me to use the oil. also the oil i bought at lowes isnt dark, like at all. i couldnt even tell i put anything on it. did i buy the wrong stuff?
WoodworkersResource
660 days ago
If you’re just looking for protection for the bowls (and they’re just for show), then oil is a fine choice. Depending on the species of wood used, oil won’t change the color of wood dramatically. If you want a darker color and still use oil you might try one of the colored danish oils that you can find at Lowes or Home Depot.
As far as using polyurethane over top the oil, that’s fine as well. Just make sure that the oil has cured completely (you won’t be able to smell the oil at all) and use a oil based poly instead of water based. Some might argue that if the oil is cured it doesn’t matter if you use water or oil based poly, but I just don’t like mixing oil and water.
Hope that helps.
View Boon's profile
Boon
660 days ago
I saw on a recent woodsmith show the host used a very dark, all natural oil that looked fantastic with only one coat. im curious because the fumes from stain is bothering me a lot and i dont think i should use it anymore. so im looking for something more natural that is very dark.
View Robb's profile
Robb
356 posts in 831 days
659 days ago
Boon, I’d guess that the dark, natural oil you mentioned above could be dark tung oil. Here’s a website that offers it:
http://www.realmilkpaint.com/
I’ve not bought the dark oil, but I have used their light tung oil with good results.
-- Robb
View Piskin's profile
Piskin
12 posts in 677 days
659 days ago
Tung oil is the way to go, most spray finishes are not safe to eat off of.
View odie's profile
odie
1602 posts in 737 days
659 days ago
Your first choice should be ... What is this bowl going to be used for ????
If for looks (display, etc.) Tung oil is the way to go with a spun on wax finish after the tung has been on 24 hours.
If you want to use this bowl and want to give a great first impression … sand to 2000 grit then put on a lemon oil wax mix sold by turners catalog. I sell these a lot this way. They can just look at them or use them … their choice.
View aaronmolloy's profile
aaronmolloy
117 posts in 677 days
657 days ago
Linsead oil is a food safe oil for cutting boards , bowls and much more hope this helps
-- A. Molloy
View Joseph Connors's profile
Joseph Connors
2 posts in 658 days
657 days ago
My first post here. This looks like a great forum. Heres my .02 worth:
All finishes are food safe once they are cured. An oil finish is the way to go for food use because some surface finishes will tend to wear and flake with repeated use and washings. HTH!
-- The new Golden Rule .... those with the gold make the rules!
View Alin Dobra's profile
Alin Dobra
316 posts in 785 days
657 days ago
Joseph Connors is right (according to “Understanding wood finishes” book). The trouble with linseed oil is that it takes a long time to cure completely. Raw linseed oil is safe for consumption but “boiled” linseed oil is not (they add heavy metals to aid in faster drying, which make it toxic).
Boon, an oil will usually bring a nice color to the wood. I use oil regularly as the first coat on any finish. There should not be any problem to put polyurethane on top of an oil like linseed oil or a “tung oil” (mix of oil and polyurethane usually). The polyurethane will give it a plasticy look though (I personally do not like it). You can get a very nice finish with a “tung oil” like Watco oil or the “salad bowl oil” made by “General”. Should you have doubts that the polyurethane will adhere to the oil, put a coat of shellac. All finishes are compatible with shellac. When you apply polyurethane, you should sand between the coats. Polyurethane is a “mechanical finish” that adheres to the previous layer by drying into the small imperfections. The sand paper creates imperfections. If your piece does not get abused (e.g. tabletop) you can probably go with just a “tung oil” finish.
Alin
-- -- Alin Dobra, Gainesville, Florida
View Bob42's profile
Bob42
285 posts in 687 days
657 days ago
If it’s food contact I use Salad Bowl Finish from Rockler.com. You have to wait about four days for it to completely cure. It looks great and slightly darkens. It’s more like a deeper look.
If it’s not contacting food I also like the tung oil and then a good paste wax rubbed in with the finest steel wool you can find.
-- Bob K. East Northport, NY
