basement window
« back to Coffee Lounge forum
Forum topic by Karda posted 04-07-2017 12:56 AM 533 views 0 times favorited 11 replies Add to Favorites Watch
View Karda's profile
Karda
1235 posts in 674 days
04-07-2017 12:56 AM
Hi, I am asking here because it isn’t a wood project but is in my shop I have old steel basement windows I want covered to keep some winter out but there is no wood to fasten to only block to any suggestions. I would like to put up Plexiglas if i can here is a pic of the window
11 replies so far
View corelz125's profile
corelz125
512 posts in 1097 days
#1 posted 04-07-2017 01:44 AM
Can you screw the plexiglass to the metal frame? Or do you have a hammer drill?
View Rrrandy's profile
Rrrandy
212 posts in 599 days
#2 posted 04-07-2017 02:00 AM
Heavy curtain?
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
Karda
#3 posted 04-07-2017 02:02 AM
cant screw to the frame, no hammer drill
View diverlloyd's profile
diverlloyd
3029 posts in 1978 days
#4 posted 04-07-2017 04:05 AM
You could put the plexi up and use some window glaze to keep it in place. I would use the glaze that is in a caulking tube, I have used both and the tube is quick and easy.
Karda
#5 posted 04-07-2017 04:14 AM
thats a thought
corelz125
#6 posted 04-07-2017 08:21 PM
can use clear silicone to do it like that also
Karda
#7 posted 04-07-2017 08:26 PM
I looked at the window again, I can’t put anything on the window itself because of the window operator. what would work well is if I could put a wood frame in and scew to the frame but I don’t know how to attach it to the block.
View JayCee123's profile
JayCee123
200 posts in 885 days
#8 posted 04-07-2017 08:44 PM
The way I did it was to attach a wood frame to the inside face of the basement wall. Along the sides and bottom used tapcons, along the top I needed to fur out the sill and attached the frame with wood screws. You can make up wood framed plexi panels and screw them to that wood frame.
Karda
#9 posted 04-07-2017 08:53 PM
ok thanks I’ll try that
View Kelly's profile
Kelly
2073 posts in 3065 days
#10 posted 04-18-2017 01:03 AM
If you can, consider a Harbor Freight impact drill. Before my Bosch’s and a Makita, I bought one believing it would die on the job I bought it for. It didn’t and I ended up giving it to a kid a few years down the road.
If you can drill just a couple holes on the top and bottom, you can mount 2×2’s and go from there.
Karda
#11 posted 04-18-2017 04:08 AM
ok I think that is what I will have to do, I think a masonary bit will do, the house was built in 1958 and the block was not as good as it is now
