marine varnish over varathane?
Forum topic by Adam Weis posted 940 days ago 2034 views 0 times favorited 3 replies Add to Favorites Watch
View Adam Weis's profile
Adam Weis
36 posts in 2191 days
940 days ago
A friend of mine made a beautiful cedar bench and applied a first coat of outdoor varathane. I told him that outdoor varathane was probably not a durable enough finish for a bench in the direct sun and the oregon rain. does anyone know if it is advisable to put marine varnish over a first coat of varathane? has anyone ever tried it?
If i had caught him earlier i would have just said use deck sealant and reapply every year. that way the bench would age gracefully, but stripping the finish at this point seems like an inordinate amount of work.
-- Adam, http://adamweisfurniture.com
3 replies so far
View CharlieM1958's profile (online now)
14863 posts in 2389 days
#1 posted 940 days ago
I can’t say I’ve done it, but I see no reason why the two finishes would be incompatible. The marine varnish just has more UV inhibitors in it.
View grizzman's profile
grizzman
5396 posts in 1474 days
#2 posted 940 days ago
i believe there both an oil based finsih and should work just fine…but ive never done that combo personally., but my thought is it should be ok..stripping it would be way to much work..your idea of a deck finish is a good one..as it would age gracefully and applying it is a breeze..
-- GRIZZMAN ...[''''']
View shipwright's profile
shipwright
3400 posts in 969 days
#3 posted 940 days ago
Both will fail at the wood / finish intersect eventually and require sanding to bare wood. I’d use Cetol.
Paul M
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
