8 inch CBN grinding wheel
« back to Woodturning forum
Forum topic by loiblb posted 04-05-2017 02:38 PM 1258 views 0 times favorited 12 replies Add to Favorites Watch
View loiblb's profile
loiblb
143 posts in 1261 days
04-05-2017 02:38 PM
Where is a good place to buy the 8 inch CBN grinding wheels?
What grit combo works?
Thanks
12 replies so far
View Nubsnstubs's profile
Nubsnstubs
1422 posts in 1936 days
#1 posted 04-05-2017 03:27 PM
I have 80 and 180 grit. Came from Woodturners Wonders. Just yesterday I saw an ad through another site that WW’s has another model wheel offered. It looks like it would be better than the ones I got. It has the full 1 1/2” face, and also has a 1” flat grinding surface on the side of the wheel. It might be better because the first ones I got are “H” shaped in profile at about 3/8” thick with a 3/8 radius, leaving about a 1” grinding face. The grinding face also has developed a slight concave surface. Sharpening bowl gouges are not a problem, but any straight flat surface will have a slight curve to it if you don’t pay attention. Not good in my opinion, but must live with it.
D Way tools also has them…........ Jerry (in Tucson)
View Wildwood's profile
Wildwood
2483 posts in 2340 days
#2 posted 04-05-2017 03:37 PM
Think this is nice to know information regardless whatever brand grinder or CBN wheels you eventually buy.
https://www.youtube.com/watch?v=WDFGa9pxCgQ
I personally like 80 grit wheels for sharpening and 46 grit wheels to repair an edge or change bevel angles. So could get by with just an 80 grit wheel. Like he says in the video he cannot tell the differences between sharpening with 80 or 180 grit wheels. Having said that lot of turners prefer higher grit wheels.
Other than ensuring wheels will fit the grinder you have or buy not much too it. Definitely shop around for those that fit your budget.
-- Bill
View TheDane's profile
TheDane
5553 posts in 3869 days
#3 posted 04-05-2017 04:15 PM
http://lumberjocks.com/reviews/3742
https://woodturnerswonders.com/collections/cbn-wheels
View Woodknack's profile
Woodknack
12431 posts in 2586 days
#4 posted 04-05-2017 06:18 PM
Does the 180 give an edge ready for turning or does it need to be touched up or stropped.
View RobS888's profile (online now)
RobS888
2512 posts in 2051 days
#5 posted 04-05-2017 06:25 PM
- Rick M
My wife hones the edge before using.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
Wildwood
#6 posted 04-05-2017 07:30 PM
No it isn’t mandatory to strop or hone your tools no matter what grit or wheel material you use. If not careful you can actually dull the tool. I go from the grinder to turning except for my skews which do hone. I may do a touch up on a gouge before going back to the grinder.
Of course that is just MHO, and screwing up stropping & honing! Plenty of turners believe you must and others just feel right thing to do!
-- Bill
TheDane
#7 posted 04-05-2017 10:00 PM
- Rick M
No need to hone gouges. I do hone skews and recently have begun honing scrapers (ala Alan Lacer).
Woodknack
#8 posted 04-06-2017 12:11 AM
Thanks Gerry.
loiblb
#9 posted 04-06-2017 01:15 AM
What speed grinder do I need for CNB wheels?
Low ,high or variable?
Thanks
TheDane
#10 posted 04-06-2017 01:19 AM
Thanks
- loiblb
Slow speed (1725rpm) is usually recommended.
Wildwood
#11 posted 04-06-2017 01:19 PM
Buy a grinder locally but do stay away from Harbor Freight. I stay away from slow-fast, and variable speed discussion. I use a high speed grinder but many prefer the slower RPM’s or variable speed grinders and that’s okay! Buying locally, can exchange or get a refund if grinder a no go.
-- Bill
TheDane
#12 posted 04-06-2017 01:27 PM
One more thought … make sure the grinder you select has the correct size arbor for the wheels you select. You want to avoid wheels that require an adapter to fit the grinder’s arbor.
My wheels (from Woodturners Wonders) are designed for a grinder with a 5/8” arbor.
