Magnets
Forum topic by Rrrandy posted 04-05-2017 12:44 AM 734 views 0 times favorited 11 replies Add to Favorites Watch
View Rrrandy's profile
Rrrandy
212 posts in 627 days
04-05-2017 12:44 AM
Does anyone know if sanding a magnet affects it’s “potency”? I drilled a hole and glued the magnet in. I failed to allow for the glue and my magnet sits about 1/128 proud of the surface.
-- Y'all need to locate a sense of humor. Borrow one if you can't find yours...
11 replies so far
View papadan's profile
papadan
3584 posts in 3516 days
#1 posted 04-05-2017 12:50 AM
Time for you to answer your question for the rest of us. LOL
View DirtyMike's profile
DirtyMike
637 posts in 1050 days
#2 posted 04-05-2017 12:58 AM
Easy now , Magnets have been a very controversial subject in the past. I sanded down some rare earth magnets flush to some wood. No change in potency .
View SawduztJunky's profile
SawduztJunky
71 posts in 1306 days
#3 posted 04-05-2017 01:00 AM
Yes, magnets can be machined. However, hard magnet materials are extremely difficult to machine, unlike flexible or rubber-type magnet materials. Magnets should be machined in the demagnetized state as much as possible (if possible) using diamond tools and/or soft grinding wheels, as temperature will have a negative effect on magnet strength.
Factors that can affect a magnet’s strength include:
Heat
Radiation
Strong electrical currents in close proximity to the magnet
Other magnets in close proximity to the magnet
Neo magnets will corrode in high humidity environments unless they have a protective coating.
-- I don't think I'm ever more "aware" than I am right after I hit my thumb with a hammer. Questions about solid surface? Just ask. http://www.swiiitch.portfoliobox.net
View Kelly's profile
Kelly
2092 posts in 3092 days
#4 posted 04-05-2017 03:36 AM
Rare earth magnets HATE heat. That aside, yes, they can be sanded, but you don’t want to get them hot or it will affect their pull.
Rrrandy
#5 posted 04-05-2017 03:38 AM
I would like to thank everyone for their response…except papadan. :)
Rrrandy
#6 posted 04-05-2017 04:27 AM
Just as an FYI I needed to find a very thin piece of metal for the opposite side of my very small magnet which is 1/4 diameter by 3/32 thick. I’m using the bottom off a peanut can, 1/128. Works great. There seems to be an attraction here…
papadan
#7 posted 04-05-2017 05:06 AM
Factors that can affect a magnet s strength include:
Heat
Radiation
- SawduztJunky
Hammers can do a number on them too. ;-)
- Rrrandy
View splintergroup's profile
splintergroup
2310 posts in 1370 days
#8 posted 04-05-2017 03:28 PM
The rare-earth magnets are very brittle and the nickel plating does a lot to protect them, but I have sanded them flush with the surrounding surface to no ill effect.
As stated, heat is a killer.
A trick for getting a flush mount is to drill a hole slightly deeper than your magnet, dab some glue into the hole (epoxy), then the magnet. Next you place a flat piece of metal across the hole. The metal will grab the magnet and align it flush with the surface until the glue dries. You can then fill in any gaps with more glue for a smooth finish.
This works even better if you recess the magnet ever so slightly. The same technique is used, but you add a piece of tape to the metal that is smaller than the hole diameter. This will force the magnet slightly deeper to the hole.
Rrrandy
#9 posted 04-05-2017 04:17 PM
Thanks Splintergroup, good trick.
View corelz125's profile
corelz125
542 posts in 1124 days
#10 posted 04-06-2017 01:06 AM
Papadan how come threads with you and magnets dont go so well?
papadan
#11 posted 04-06-2017 01:59 AM
- corelz125
I dun no, sumpin ta do wit my magnetic pursonalty
