Need help.
Forum topic by buckbuster31 posted 04-04-2017 08:09 PM 573 views 0 times favorited 8 replies Add to Favorites Watch
View buckbuster31's profile
buckbuster31
254 posts in 663 days
04-04-2017 08:09 PM
A client is wanting this made, and to be honest I’m not sure how to bend th wood and everything. any recommendations?
8 replies so far
View Loren's profile
10477 posts in 3795 days
#1 posted 04-04-2017 08:40 PM
I think a bend that gentle in pine can be done
by sluicing boiling water on the board and
bending. You’ll probably want to use a
come-along or something like that.
Easier way to do it is get a 4×8 sheet of 3/8”
bending ply and laminate.
buckbuster31
#2 posted 04-04-2017 08:47 PM
What is bending ply?
View Craftsman on the lake's profile (online now)
2810 posts in 3585 days
#3 posted 04-04-2017 08:54 PM
Plywood of any kind should bend up to 1/2 inch? Possibliy a couple of 1/4” pieces glued together while bending?
View pontic's profile
pontic
634 posts in 756 days
#4 posted 04-04-2017 08:57 PM
Use the boiling water technique to bend make dados straight and a little bigger graduated on up so they will pinch the shelves tight and not crack them. Kerf saw th bow part with a Japanese saw or a wide bach saw. I agree you will need a comealong.
-- Illigitimii non carburundum sum
View JollyGreen67's profile
JollyGreen67
1676 posts in 2910 days
#5 posted 04-04-2017 09:07 PM
Somebody has been watching DIY – Maine Cabin Builders. :o))
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
View jbay's profile
jbay
2678 posts in 1046 days
#6 posted 04-04-2017 09:20 PM
I would cut the back first then screw all of the shelves to it.
Then I would use a couple of layers of thin wood (your choice) and screw them to your shelves and back working from the bottom to the top.
Then I would make a Face Frame for the front
If it were me, and I was painting it, I would probably use 2 layers of 3/8” mdf for the sides. But you could use anything you want as long as it will bend.
I would pass on trying to use solid wood and soaking it.
View Woodknack's profile
Woodknack
12369 posts in 2527 days
#7 posted 04-05-2017 01:04 AM
My FIL built several and he’s not much of a woodworker so it can’t be too hard. I would go with a couple or three layers of 1/8 ply.
View SawduztJunky's profile
SawduztJunky
71 posts in 1305 days
#8 posted 04-05-2017 01:22 AM
Yeah. Layers of thinner ply glued & attached one at a time would probably be the easiest.
-- I don't think I'm ever more "aware" than I am right after I hit my thumb with a hammer. Questions about solid surface? Just ask. http://www.swiiitch.portfoliobox.net
