Long Term Storage of Power Tools
Forum topic by Jimbo1953 posted 04-04-2017 03:51 PM 413 views 0 times favorited 5 replies Add to Favorites Watch
View Jimbo1953's profile
Jimbo1953
2 posts in 379 days
04-04-2017 03:51 PM
I’m in the process of moving and will need to put my table saw and jointer in storage for up to 8 months. I’d like to get some ideas to prevent rust from forming on the cast iron tops. I was thinking of applying a coat of Boeshield (which I’ve never used) and then wrapping the tops in plastic wrap. Any thoughts? Also, is there anything else I should do to protect them? They will be stored in a storage unit which I may have access to check on them, but if not I’d like to know I will not have to use a bunch of elbow grease to get them back in useable shape.
-- Jim, Bakersfield, CA
5 replies so far
View Jack Lewis's profile
Jack Lewis
245 posts in 983 days
#1 posted 04-04-2017 04:18 PM
Living in Bakersfield, a good coat of protection should suffice. Wrapping in plastic might trap moisture that would otherwise evaporate naturally. A periodic check on condition and re-oiling them if needed would be better than removing a heavy surface coat.
In the navy, every day at the end of the day machines were oiled but then that was Hawaii.
-- "Now we are getting no where, thanks to me"
View BigYin's profile
BigYin
406 posts in 2321 days
#2 posted 04-04-2017 04:27 PM
http://www.brownells.com/gun-cleaning-chemicals/oils-lubricants/rust-prevention/rust-preventive-no-2--prod1124.aspx
spray everything … dont wrap in polythene
-- ... Never Apologise For Being Right ...
View dhazelton's profile
dhazelton
2687 posts in 2201 days
#3 posted 04-04-2017 04:43 PM
Cosmoline or the cheapest tube of wheel bearing/axle grease you can get.
MrUnix
6348 posts in 2104 days
#4 posted 04-04-2017 05:42 PM
Just wax and cover with something breathable – plastic is not a good idea. Sometimes it helps to lay down a sheet of cardboard on the table tops first, then cover. Packing blankets work well. BTW: T9 is just paraffin wax and mineral oil in a solvent (mineral spirits). Paste wax is paraffin (and a few others) in Naphta. I had a machine stored in a non-conditioned warehouse for over 2 years (S. Florida), and it looked just like when I originally stored it after I got it back using the above technique (using JPW). YMMV.
Jimbo1953
2 posts in 379 days
#5 posted 04-05-2017 03:34 PM
My apologies. I neglected to mention the tools will be stored in Sequim, Washington, not Bakersfield, CA
