wonky chip breaker question
« back to Hand Tools forum
Forum topic by fo57 posted 04-04-2017 03:50 PM 585 views 0 times favorited 8 replies Add to Favorites Watch
View fo57's profile
fo57
5 posts in 472 days
04-04-2017 03:50 PM
Topic tags/keywords: plane blade
I have a #4 Record hand plane (around 15 years old). I was never happy with the chip breaker. Despite attempts to flatten it, I always got shavings that slid between it and the blade. The blade is flat. I’ve used it with other chip breakers. Eventually, I replaced the chip breaker and blade with a Hock set up, and relegated the original to scrub plane work. And it works fine, but even with the chip breaker pulled back, I still get shavings between it and the blade. This doesn’t keep it from working: I’m just hogging out material. But it drives me batty.
So my question: could I heat the chip breaker and introduce a bit more curve in order to better seat it to the blade? Is it made of O1 steel? Or will I just screw it up?
P.S.: I feel pretty confident about re-heating if the metal is O1. Anyone know what it is?
-- Frank O.
8 replies so far
View Ron Aylor's profile
Ron Aylor
2649 posts in 701 days
#1 posted 04-04-2017 04:02 PM
... heat the chip breaker and introduce a bit more curve in order to better seat it to the blade?
- fo57
Why would you want more curve? The goal is to get the chip breaker to seat on a flat plane … if you are getting shavings between the chip breaker and the iron … one of the two is not flat (if not both).
View HokieKen's profile (online now)
HokieKen
5622 posts in 1192 days
#2 posted 04-04-2017 07:24 PM
Have a read through this blog post I did on fitting a chipbreaker during a plane rehab. I think it’ll answer some questions for you!
-- Kenny, SW VA, Go Hokies!!!
View fo57's profile
fo57
5 posts in 472 days
#3 posted 04-05-2017 02:02 AM
My writing is not the best, so I didn’t make myself clear. One side of the chip breaker is high. I have worked it down in an effort to straighten it out. But one side is still high and am concerned that if I keep filing away at it, the chip breaker will overall not have enough pressure at the edge. So I was thinking that I could introduce a little more of a curve (at the hump part) and that would give me more metal to work with to re-establish a straight/flat contact and keep sufficient pressure at the edge.
I have other hand planes and have successfully adjusted the chip breakers to look like the photo that Ron sent and am happy with their performance even in oak.
Kenny, I will check you blog post. Thank you both for responding.
-- Frank O.
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15379 posts in 2672 days
#4 posted 04-05-2017 02:31 AM
Yes, you can place the curve of the chip breaker in the vise (breaker will be upside down) and put additional bend in the breaker. No harm, no foul. No heat required.
View fo57's profile
fo57
5 posts in 472 days
#5 posted 04-05-2017 02:41 AM
Prefect! Thanks.
-- Frank O.
View Hammerthumb's profile
Hammerthumb
2862 posts in 2029 days
#6 posted 04-05-2017 03:00 AM
- Smitty_Cabinetshop
Smitty is spot on. No heat required.
-- Paul, Las Vegas
Ron Aylor
#7 posted 04-05-2017 10:22 AM
^ agree … should bend just fine!
HokieKen
#8 posted 04-05-2017 03:16 PM
That’s exactly what I do in the blog post linked above :-)
