Screwed
Forum topic by rwe2156 posted 04-04-2017 01:50 PM 1476 views 2 times favorited 45 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
2881 posts in 1446 days
04-04-2017 01:50 PM
[RANT]
Screw engineer 1: “Hey, lets design our screws so they take 3 different size bits!”
Screw engineer 2: “Great idea. And how about this: design the bits so they’re rounded on the end AND they fit a little loose that way they will wobble all over the place when you run the screw in!”
Bit engineer: “Lets design a nifty little bit hold with a sleeve to prevent that”
User: “Crap, now where did I put that other bit…...(walking back to the shop cussing)
[/RANT]
45 replies so far
View diverlloyd's profile
diverlloyd
2663 posts in 1823 days
#1 posted 04-04-2017 01:54 PM
Welcome to the designed to fail philosophy that all started with the light bulb.
View Monte Pittman's profile
Monte Pittman
28933 posts in 2304 days
#2 posted 04-04-2017 02:09 PM
They should ban Phillips screws.
Yes, very loose tolerance on what is allowed.
-- Mother Nature created it, I just assemble it.
View waho6o9's profile (online now)
waho6o9
8165 posts in 2542 days
#3 posted 04-04-2017 02:11 PM
If you can’t GRK it:
Spax it:
View Nubsnstubs's profile
Nubsnstubs
1280 posts in 1696 days
#4 posted 04-04-2017 02:22 PM
I give Torx another 10 years or so, and you’ll all be complaining about them like you’re complaining about Phillips today. I’ve watched people using a #1 Phillips screwdriver on a #2 screw, and wonder why it slips. I’ve even seen people try to stuff a #3 bit or screwdriver into a #2 screw. It’s not always the parts nor the tool. It’s the user. The only problem I’ve found with Phillips drivers is they wear out too soon…....... jerry (in Tucson)
View UpstateNYdude's profile
UpstateNYdude
914 posts in 1948 days
#5 posted 04-04-2017 02:24 PM
Personally my favorite screw heads are square, I’ve never rounded one out and they always seem to fit tight with whatever bit comes in the box.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
Monte Pittman
#6 posted 04-04-2017 02:28 PM
Jerry is correct, you “should ” use the right tool in the right screw. I do think that Phillips and flat blade screws lend themselves to improper tool use more than others.
I am a torx fan. As much as possible, that’s all I use.
View bbasiaga's profile
bbasiaga
1200 posts in 1961 days
#7 posted 04-04-2017 02:29 PM
And then you finally find that right bit and the screw head material is so soft it strips out anyway. Or you get all but the last two threads in the pilot hole and the top twists right off.
Brian
waho6o9
#8 posted 04-04-2017 02:40 PM
No cam outs with the square ones as well:
View shipwright's profile
shipwright
7966 posts in 2763 days
#9 posted 04-04-2017 02:54 PM
Come to Canada, the land of Robertson. The only place you find Phillips is in imports from USA.
View Manitario's profile
Manitario
2629 posts in 2848 days
#10 posted 04-04-2017 02:56 PM
I’m not sure if it’s a Canadian thing, but you can only really buy Robertson (square) drive screws up here. They work great with minimal cam-out. I agree with the complaints about Phillips screws, I try to avoid ever having to use them.
View Woodchuck2010's profile
Woodchuck2010
707 posts in 824 days
#11 posted 04-04-2017 03:08 PM
Spax has some good screws in many different drives. They have a Uni drive screw that takes either a #2 phillips OR square bit. I like the square.
-- Chuck, Michigan,
View AHuxley's profile
AHuxley
652 posts in 3287 days
#12 posted 04-04-2017 03:22 PM
- rwe2156
View GR8HUNTER's profile
GR8HUNTER
3639 posts in 678 days
#13 posted 04-04-2017 03:51 PM
LMAO ….not at you rwe …with you knowing exactly what you mean …...I do love square drive myself
-- Tony Reinholds,Pa. REMEMBER TO ALWAYS HAVE FUN
4954 posts in 2459 days
#14 posted 04-04-2017 03:52 PM
I’ve long thought there should be a federal law banning slotted screws, and the only time phillips was allowed is on drywall screws (the cam-out helps with that application). While I’m not find of Torx, they do work well but with square you can have 3 drivers to cover like 90% of the screws, and then add a couple more for the rest, and they grip just as well as torx (my opinion) although with torx you an drive at a slight angle.
View Jack Lewis's profile
Jack Lewis
263 posts in 1044 days
#15 posted 04-04-2017 04:12 PM
Jerry; You can fix stupid!
-- "PLUMBER'S BUTT! Get over it, everybody has one"
showing 1 through 15 of 45 replies
