Two even dumber questions....
« back to Coffee Lounge forum
Forum topic by poopiekat posted 10-26-2010 01:48 AM 1147 views 0 times favorited 10 replies Add to Favorites Watch
View poopiekat's profile
poopiekat
4408 posts in 3976 days
10-26-2010 01:48 AM
Topic tags/keywords: question
#1) Hey, what happened to Gorilla glue in Canada? Why has polyurethane glues disappeared from the shelves here? Neither HD, Rona, or my favorite millwork/hardware place had a single bottle? Not even the Elmer’s version of Gorilla Glue??
And #2.) Where can I find 1000 grit sandpaper? Preferably waterproof, silicon carbide, stearated? Nobody has anything higher than #600 grit. An online source would be good, a Canadian online place would be even better!
thanks, all!
10 replies so far
View 8iowa's profile
8iowa
1591 posts in 4003 days
#1 posted 10-26-2010 01:53 AM
I like to use 400, 600, 800, and 1200 grits on glass for sharpening. I can’t find these at the big boxes. I haven’t had much luck at auto supply stores either.
You can order them from Highland Woodworking in Atlanta ( www.highlandwoodworking.com ). I often stop in there when traveling on I 75.
poopiekat
#2 posted 10-26-2010 02:03 AM
Thanks, 8iowa! Looks like I could solve both of my dilemmas with an order there! I’ll give them a try…
View GaryL's profile
GaryL
1099 posts in 3072 days
#3 posted 10-26-2010 02:12 AM
Try an auto body supplier. Sometimes an auto supply store will have a small section for auto body work. The 1000 is common for wet sanding (or color sanding) auto finishes before buffing.
-- Gary; Marysville, MI...Involve your children in your projects as much as possible, the return is priceless.
View quartrsawn's profile
quartrsawn
146 posts in 3455 days
#4 posted 10-26-2010 02:14 AM
Try Red Hill Corp. .... www.supergrit.com
-- Nat - West Sayville,L.I., NY
View sras's profile
sras
4970 posts in 3371 days
#5 posted 10-26-2010 03:32 AM
I found the finer grit sandpaper at a supply store for automotive finishes – all the way up to 2000 grit.
View Moron's profile
Moron
5032 posts in 4135 days
#6 posted 10-26-2010 03:44 AM
I bought one bottle of Gorilla glue in Canada, and to be honest…................it didnt work. Joint broke, dissappointing.
be careful with silicone carbide papers, some are arguementative with catalytic lacquers but are sold at CT and most automotive finsihing supply stores.
View shipwright's profile
shipwright
8189 posts in 3040 days
#7 posted 10-26-2010 08:01 AM
I don’t understand. I’m on Vancouver Island and we’ve got Gorilla glue at all the stores here. I know that for a fact because in the last week I’ve visited all of them looking for Urea Formaldehyde glue, which none of them had. They all had lots of PVA glues, polyurethanes and contact cements but as usual not what I was looking for. I finally found some UF at a marine supplier.
I buy wet / dry sandpaper at the local auto parts store up to 2000 grit.
Paul M
View racerglen's profile
racerglen
3112 posts in 3022 days
#8 posted 10-26-2010 02:07 PM
And if you REALY want a fine grit, Lee Valley’s got either pva backed or bare backed stuff that goes down to .05 microns !
-- Glen, B.C. Canada
View dusty2's profile
dusty2
323 posts in 3671 days
#9 posted 10-26-2010 11:07 PM
Paul – are you using UF for an indoor or outdoor project. Also, is this an MDF project that you are working on.
-- Making Sawdust Safely
shipwright
#10 posted 10-27-2010 12:52 AM
Hi Dusty
It’s another veneered box, the successor to Oops! It is to glue the veneer to the MDF base. Problems I don’t know about? It’s a small enough project that I’m not worried about the gases. My other veneer projects have all developed tiny dips at veneer joints from the PVA glue receding. The Marquetry Society recommends a hard drying glue (UF) to beat the problem. I’m running a vacuum bag test right now to check effectiveness.
Paul M
