Feasibility of exterior door
Forum topic by ppg677 posted 04-04-2017 02:01 AM 367 views 0 times favorited 3 replies Add to Favorites Watch
View ppg677's profile
ppg677
148 posts in 760 days
04-04-2017 02:01 AM
I have an exterior door on the 2nd story of my home that I’d like to replace. If it is feasible, it seems like a good door to attempt a DIY build. It is not used often and has a nice storm door in front. I’d prefer not to spend a lot for a rarely used door yet I want the inside to look nice because it is in a master bedroom (no cheap steel door!). I figure with a wood door I can just hang it using the existing frame and hinges and hand plane to nail down shape.
My wife would prefer full light and it appears I can buy a glass insert like this that takes up most of the door: https://www.zabitat.com/u/odl-perspectives-low-e-door-glass---textured-vapor---24-x-66-evolve-frame-kit-686le-vpr
I’ve made fine furniture projects so I’m not a complete novice.
I figure rail and stiles are obviously the way to go. Perhaps use a quartersawn white oak. There wouldn’t be a panel because the opening would be taken up by the glass insert. But it also seems like laminating 3 pieces of solid wood with epoxy is the way to go to form a 1.75” door?
Thoughts on this? Including robust joinery for the rails/stiles?
With.a 36” wide door and a 22” wide glass insert, I’m looking at 7” wide stiles.
3 replies so far
View TungOil's profile
TungOil
841 posts in 399 days
#1 posted 04-04-2017 02:09 AM
A solid wood door is not as well insulated as a steel or fiberglass door. Something to consider in the master bedroom…. I believe fine homebuilding just did an article about a year ago About making insulated wooden doors that you might want to check out
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
ppg677
#2 posted 04-04-2017 02:14 AM
I imagine a mostly glass door will be as insulated as the glass insert.
ppg677
#3 posted 04-04-2017 03:15 AM
Looks like Freud put together a guide!
http://go.rockler.com/tech/RTD10000539AA.pdf
