New to spraying - questions...
Forum topic by Jim Dawson posted 04-03-2017 05:08 PM 441 views 1 time favorited 6 replies Add to Favorites Watch
View Jim Dawson's profile
Jim Dawson
103 posts in 737 days
04-03-2017 05:08 PM
I just bought a Fuji HVLP system and have a project I want to spray.
I’m building, for my daughter-in-law, a large dog crate with a top that will double as a folding table in her laundry room. It will be made from poplar with a baltic birch plywood top. She has picked a particular color white that matches her cabinets.
Can I use sprayed Sealcoat as a primer under waterborne latex enamel? IF not, could anyone offer a solution that would provide a reasonably durable surface that can be sprayed?
Thanks,
Jim
View CharlesNeil's profile (online now)
CharlesNeil
2230 posts in 3776 days
#1 posted 04-03-2017 06:11 PM
if your going to paint, the simplest and easiest is to check with your Sherwin williams, and see if they can mix your color in Kem Aqua Plus, its a water base finish , usually they can do light and white colors, if so shoot a coat and let that be your primer , then scuff sand with 320 to remove raised grain, and continue, usually 2 to 3 coats, I personally prefer to use a clear coat over it, same Kem Aqua, lot less fuss and mess …
View Carloz's profile
Carloz
1147 posts in 497 days
#2 posted 04-03-2017 07:16 PM
I would not use shellac as a primer for latex paint. Check the label on the paint, it should suggest you the primer it should go with. I would stick to the same manufacturer as they are supposed to make their products work with each other.
Jim Dawson
#3 posted 04-03-2017 08:58 PM
Thanks for the tips. I’ll forget the shellac.
View pintodeluxe's profile
pintodeluxe
5566 posts in 2718 days
#4 posted 04-03-2017 09:06 PM
Most stores have a premium line of Acrylic paint appropriate for cabinets. I use Breakthrough from Miller paint. It sprays well if you thin it slightly with water.
View 01ntrain's profile
01ntrain
237 posts in 975 days
#5 posted 04-03-2017 09:12 PM
Just shot a cabinet job and used SW Pro Classic Alkyd, it’s a water-based Alkyd, similar to Benjamin Moore Advance. It turned out pretty well considering that I used an LVLP setup and had some issues with weather changes. With the Fuji, you should get a better result. I started with their Multi-Purpose Primer and I think the combination of the two will have an attractive, yet tough finish.
Jim Dawson
#6 posted 04-03-2017 09:19 PM
Thanks for the other choices. I think the color they picked is a Benjamin Moore color.
