Trimming Edge Banding on Plywood
Forum topic by RoadKing598 posted 10-25-2010 03:29 PM 4345 views 0 times favorited 6 replies Add to Favorites Watch
View RoadKing598's profile
RoadKing598
5 posts in 2693 days
10-25-2010 03:29 PM
Topic tags/keywords: plywood trimming edge banding technique question
I recently was asked by some friends to build them a very simple cabinet for their laundry room that they ultimately wanted to paint. I choose 3/4” plywood knowing that I would have to cover the edges somehow (something I haven’t done before).
I used the iron-on edge banding to cover the exposed ply and the application process went very well (thank you honey for the use of your iron). However, I am curious as to how most folks approach trimming the edge banding down to the plywood. The package suggests and fancy edge trimming tool, a razor blade, or sanding. I can see folks considering a sharp chisel as well as a viable option.
I am nervous about damaging the thin veneer on the ply and am curious how the experts attack this problem. Any advise would be welcomed!
-- Eric, Central Wisconsin, Bring on the knowledge!
16272 posts in 4088 days
#1 posted 10-25-2010 04:27 PM
I use a gizmo like knucklenut posted a link to.
Another alternative to consider: Rather than the iron-on banding, I often use 3/4” screen molding. It’s easy to tack or glue on, and adds a nice radius to the edge. It’s not for every situation, but a good solution sometimes.
View MrsN's profile
MrsN
982 posts in 3396 days
#2 posted 10-25-2010 06:15 PM
I used the razor blade method once, If I ever do it again I will get the tool for it. Most of the time with large projects I prefer to do some type of face framing over the plywood edges.
On a small project that I was painting recently I used some wood filler on the edges and sanded that smooth, then painted. It worked really well, but would be a pain for a large project.
27251 posts in 3692 days
#3 posted 10-25-2010 06:35 PM
I am with Charlie and Knucklenut on this one. It can be done with a utility knife and new blade or just a blade alone. But you have to be careful and it takes a while. With the trimmer the edges can be flush trimmed with one pass.
RoadKing598
#4 posted 10-25-2010 06:46 PM
Thanks for all of the replies so far…seems clear so far.
As a follow-up, if I were to use one of these trimmers as recommended, is there such a thing as “grain direction” on the edge-banding? If so, I presume that the direction I move the tool will matter…any thoughts or words of wisdom here?
Thanks again all!
View ArtistryinWood's profile
ArtistryinWood
107 posts in 3557 days
#5 posted 10-25-2010 07:27 PM
I like the way this guy does it.
http://www.youtube.com/watch?v=PEEYTA3eymc&feature=mfu_in_order&playnext=1&videos=gjum8SfGUkg
Andrew
-- It seem's to me i could live my life, a lot better than i think i am. Andrew, Midland, Ont.
View davcefai's profile
davcefai
37 posts in 3267 days
#6 posted 10-25-2010 07:38 PM
Yes there may well be a grain direction. If so the trimming tool will attempt to plough into the grain and nick the plywood. All you can do is examine the banding and decide which end to work from.
FWIIW I gave up on iron-on banding. It tends to come off. I rip a length of 5 to 10mm thick wood and use that. Trim with a plane or router.
-- David
