12" Bandsaw blade replacement
Forum topic by plywoodman posted 04-01-2017 11:10 PM 722 views 0 times favorited 14 replies Add to Favorites Watch
View plywoodman's profile
plywoodman
12 posts in 596 days
04-01-2017 11:10 PM
Topic tags/keywords: band saw blade
I have a Craftsman 12” where the blade broke. In replacing the blade, I bought a 12” blade from Lowes that is too big. I’ve tried adjusting the saw all the way out, without success. Is this usual for a store-bought blade, and is my only option to buy from Craftsman?
-- Don, Arizona. " How hard can it be "?
14 replies so far
View MrUnix's profile
MrUnix
6830 posts in 2255 days
#1 posted 04-01-2017 11:13 PM
I would never buy a blade from the manufacturer. There are dozens of sources for band saw blades – you just need to know the proper length. And you can always have them made to any size. Your manual should have the proper length blade needed – not all 12” saws are the same, particularly across manufacturers and models.
View Rich's profile
Rich
3206 posts in 645 days
#2 posted 04-02-2017 12:12 AM
I have an Atlas Press Co 12” band saw that uses 82” blades. You can use a piece of string, or anything flexible, to wrap around the wheels and mark the length with a marker. Then stretch it out and measure.
View TungOil's profile
TungOil
979 posts in 551 days
#3 posted 04-02-2017 12:47 AM
Since you hav a broken blade, lay it out on the floor and measure it. It is probably 80”.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
woodbutcherbynight
5290 posts in 2465 days
#4 posted 04-02-2017 01:59 AM
Try a Timberwolf or wood slicer much better blades and performance. LINK
I recently called them and asked what blade would work best for my circle cutting jig. The blade they recommended works great, as did the resaw blade I bought last year.
View CharlesA's profile
CharlesA
3332 posts in 1854 days
#5 posted 04-02-2017 02:04 AM
It depends on which Craftsman 12” you have, the newer Rikon model or one of two older models. That’s three different blade lengths, I think. Mine is one of the newer ones and Olson, Timberwolf, Highland woodslicer, and others carry that 89 1/2” blades.
View JollyGreen67's profile
JollyGreen67
1676 posts in 2819 days
#6 posted 04-02-2017 02:22 AM
+ for TungOil
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View Wood_Guy_CR's profile
Wood_Guy_CR
5 posts in 1556 days
#7 posted 04-02-2017 08:04 PM
Don,
If your BS is an older model, vintagemachinery.org may have the manual for it which will list the blade size you need. Also, many saws have the size cast or stamped into the frame. As mentioned above, most big box stores only carry blades for modern machines which may or may not be what you need! My 12” C-man BS is a 40’s vintage machine which needs an 80” blade, a size my big box’ers don’t have. I ordered a Timberwolf off of Amazon and love it!
Try Amazon, Rockler, Woodcraft or Highland.
Guy
-- Expect Success, Plan for Failure!
Craftsman on the lake
2796 posts in 3494 days
#8 posted 04-02-2017 08:15 PM
I’ll bet your blade is 80 inches. Measure it by putting your sliding rule around it from wheel to wheel.
View joey502's profile
joey502
539 posts in 1574 days
#9 posted 04-02-2017 08:44 PM
I have a 12” craftsman, 89.5” blade. I order them from a shop in NC called woodcraft bands. They are about 1/3 the cost of buying from sears.
plywoodman
#10 posted 04-03-2017 04:35 AM
Thanks, guys. It is an older machine. So old that the model number 113. 243410, doesn’t even show up on the Craftsman website! I’ll try your suggestions and let you know how it goes.
View BurlyBob's profile
BurlyBob
5661 posts in 2321 days
#11 posted 04-03-2017 03:32 PM
Hartville tools sells blades at a decent price with no shipping. I’ve bought else where for less but the shipping ruined the deal.
View MrRon's profile (online now)
MrRon
4869 posts in 3299 days
#12 posted 04-03-2017 06:19 PM
Two things determine the length of a band saw blade; wheel diameter and the distance between wheels. To get the correct length, 1) Find the circumference of the wheel. In your case; C = 12” x 3.14 or 37.68”. 2) measure the distance between the center of the top wheel to the center of the bottom wheel. 3) Add 37.68” to twice the distance measured in step 2. Round up or down to the nearest whole number. Not all band saws have the same dimensions, unless they are exact copy clones.
MrUnix
#13 posted 04-03-2017 06:28 PM
- MrRon
Or just use an online calculator like this one over at the VM site:
Belt or Band Saw Length
Of course, if it’s one of the three wheelers, then you have to resort to other methods such as those described by some others above.
View GR8HUNTER's profile
GR8HUNTER
4151 posts in 768 days
#14 posted 04-04-2017 03:43 AM
IF ITS THIS SAW IT IS AN 80” blade i have bought them at lowes already
