Why can't I...
Forum topic by airman posted 10-24-2010 11:13 PM 1890 views 0 times favorited 21 replies Add to Favorites Watch
View airman's profile
airman
51 posts in 3330 days
10-24-2010 11:13 PM
drill a straight hole!!?? Just got thru turning a pepper mill. Using the marks from the lathe I drill the hole for the mechanisms and the hole is not centered. I checked the drill bit to be sure that it was 90 degrees to table and that the mill also ninety degrees. The hole still exited off center. This is not the first time this has happened to me. Maybe I should try for off center and then it would drill true.
21 replies so far
117203 posts in 3691 days
#1 posted 10-24-2010 11:28 PM
If your using a drill press your table might not be set to 90 degrees
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3229 days
#2 posted 10-24-2010 11:40 PM
when you stand infront of your drillpress you maybee have set the table 90 degree left to right
but have you checked it in out that it is in level
just a thought
Dennis
View ChuckV's profile
ChuckV
3156 posts in 3641 days
#3 posted 10-25-2010 12:02 AM
I do not know how you are supporting the piece on the drill press table. But, once you have the table set 90 degrees to the bit, you need to also be sure that that the piece is 90 degrees to the table both left-to-right and front-to-back – in other words, parallel to the bit.
Best wishes.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View interpim's profile
interpim
1170 posts in 3572 days
#4 posted 10-25-2010 12:06 AM
why not get a jacob’s chuck for your lathe and use the tailstock to drill your hole. That way the piece stay’s in your chuck. I use a cheap Jacob’s chuck from HF and it works great.
-- San Diego, CA
View Howie's profile
Howie
2656 posts in 3037 days
#5 posted 10-25-2010 12:24 AM
How long is the bit? Are you pressing too hard and causing it to flex? Just a thought.
-- Life is good.
View shipwright's profile
shipwright
8055 posts in 2912 days
#6 posted 10-25-2010 12:43 AM
What kind of bit are you using? If this is a pepper mill, you are likely drilling down the grain. A forstner bit will be less likely to wander than a twist drill or spade bit.
Paul M
View Dark_Lightning's profile
Dark_Lightning
3215 posts in 3223 days
#7 posted 10-25-2010 01:02 AM
Depends on the size of the bit. Skinny bits tend to wander, following the softer grain. It also possible that the end you marked (live center, probably) may not have been square to the centerline of the pepper mill. Did you hole the mill in a clamp or vise when drilling? This will also cause the problem.
-- Random Orbital Nailer
View lew's profile
lew
12262 posts in 3869 days
#8 posted 10-25-2010 01:07 AM
Interpim hit the perfect solution.
I had the same problems and tried everything to get a perfectly centered through hole. Finally, got the jacobs chuck for my lathe and haven’t had any trouble since. If you are using forstner bits, also get an extension for the bits. It really saves time because you don’t have the rotate the blanks half way thru.
View richgreer's profile
richgreer
4541 posts in 3188 days
#9 posted 10-25-2010 01:26 AM
The right (perhaps only) way to make a pepper mill is to drill the hole before you turn it.
View hairy's profile
hairy
2750 posts in 3646 days
#10 posted 10-25-2010 01:26 AM
If you have a live center, you could drill the hole in the blank before you turn it. You put a cone on the center, then put the cone into the drilled hole. I used that on a cane.
There are others, but I know this one.
-- My reality check bounced...
shipwright
#11 posted 10-25-2010 02:56 AM
Of course you’re right Rich. You know they say common sense just isn’t common any more. Fortunately some (you) still have it. Good call.
Paul M
View crank49's profile
crank49
4032 posts in 3085 days
#12 posted 10-25-2010 03:21 AM
It’s always best to do as many operations as possible with a given setup.
While the part is chucked in the lathe is the best time to drill it, like “interprim” said, using a drill in a Jacobs chuck, mounted in the tailstock
Unless the part had to be supported by both the chuck and the live center in the tailstock at the same time.
In the later case, Rich hit it. Drill, then turn.
View TheGravedigger's profile
TheGravedigger
963 posts in 4138 days
#13 posted 10-25-2010 03:30 AM
I’m with hairy. I make it a habit, whenever possible, drilling the hole on the lathe first, then turning around the hole.
-- Robert - Visit my woodworking blog: http://littlegoodpieces.wordpress.com
View sras's profile
sras
4866 posts in 3243 days
#14 posted 10-25-2010 03:35 AM
If you do need to drill a deep hole and keep it straight, one thing that can help is to back the bit out and maek sure the chips are clear out of the bit. If the bit gets clogged it can make it easier to wander. This is especially true for smaller diameter bits.
TopamaxSurvivor
18355 posts in 3790 days
#15 posted 10-25-2010 06:29 AM
What lind of bit? A self feeding auger will drill straighter than a twist drill. A shell auger is better yet. Check this out http://lumberjocks.com/reviews/1694
