CMT template my way
Forum topic by woodman71 posted 939 days ago 1135 views 3 times favorited 5 replies Add to Favorites Watch
View woodman71's profile
woodman71
139 posts in 1492 days
939 days ago
Hello everyone, well the holiday season is coming fast. So this year, I’m going to give x-mas gifts of the CMT tray. I was tracing the template that is in the kit and I found that there was too much room for error, as trying to keep the walls even and spacing right. After some thought I came up with this idea. By taking sometime and care using the CMT template I was able to get the spacing right. I started by doing it the way CMT says to taking care to get the space right once I had it looking good to me. I drilled starting hole for my jig saw, cut to just outside the lines and then I put the CMT template back on and again taking care to get it back where it was when I traced it. Then using a flush bit I cut it out. By making this template it does two things. I still trace the template and then drill out the compartments but if you look close at the pictures. I now screw the template down and then trace it by doing this. I’m able to put the template back in the screw holes. And I don’t have to reposition the template when routing. Here’s some pictures of my work.
5 replies so far
View Bob Kollman's profile
Bob Kollman
1779 posts in 1359 days
#1 posted 939 days ago
Looks good, when you fill it with x-mas shrimp and caviar I hope you’ll give me a call to
try it out!!!! :)
-- Bob Kenosha Wi.
woodman71
#2 posted 939 days ago
Thanks Bob I will posted it when done
View freidasdad's profile
freidasdad
135 posts in 1155 days
#3 posted 918 days ago
This is a great idea!! I haven’t started using my templates from the kit yet but I figured that the alignment was going to be fussy….
-- My goal in life is to be as good a person as my dog already thinks I am---author unknown
View Bob42's profile
Bob42
451 posts in 1958 days
#4 posted 918 days ago
I agree that is a great idea. It should make it easier. Thanks for sharing the idea and the post.
-- Bob K. East Northport, NY
View Roger's profile
Roger
9191 posts in 972 days
#5 posted 918 days ago
Great little how to. Thnx for sharing
