Guide bearing maintenance
Forum topic by Spoctor posted 03-31-2017 10:01 PM 665 views 0 times favorited 8 replies Add to Favorites Watch
View Spoctor's profile
Spoctor
8 posts in 795 days
03-31-2017 10:01 PM
Topic tags/keywords: bandsaw blade guides tool
Gentlemen,
I have a Craftsman 10” bandsaw, which uses ball bearing blade guides. I have just discovered that the two lower guides are virtually locked up. I suspect that may be due to fine sawdust working into the race and gumming it up. Any thoughts on how to clean and lube these bearings, or will I have to buy new ones?
8 replies so far
View SawduztJunky's profile
SawduztJunky
71 posts in 1239 days
#1 posted 03-31-2017 10:03 PM
Try some ZEP 45 I use it on all my router bearings.
-- I don't think I'm ever more "aware" than I am right after I hit my thumb with a hammer. Questions about solid surface? Just ask. http://www.swiiitch.portfoliobox.net
View papadan's profile
papadan
3584 posts in 3449 days
#2 posted 03-31-2017 10:10 PM
I use brake parts cleaner in a spray can.
View Woodknack's profile
Woodknack
12220 posts in 2461 days
#3 posted 04-01-2017 12:02 AM
Check if they are roller skate size because you can buy them by the dozen for dirt cheap
View Jim Finn's profile
Jim Finn
2663 posts in 3002 days
#4 posted 04-01-2017 12:04 PM
You can usually buy bearings of that size for about $5, from a bearing shop.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
View HorizontalMike's profile
HorizontalMike
7769 posts in 2995 days
#5 posted 04-01-2017 04:39 PM
I use 608RS skate bearings because they fit and are cheap. $12 bucks for 10. At least these are the bearings on my 14in Rikon. Double check your existing bearings and go shopping.
https://www.amazon.com/608-2RS-Bearing-Rotating-Pre-Lubricated-precision/dp/B01GLQXYZ4/ref=sr_1_4?s=industrial&ie=UTF8&qid=1491064475&sr=1-4&keywords=608rs+ball+bearing
XiKe
608-2RS Bearing 8×22x7 Ball Bearing. Rotating quiet, High speed and Long life. Double seal / Pre-Lubricated / ABCE-3 precision. 608RS Ball Bearing (10 Set).
Sale: $11.99 ($1.20 / Item) & FREE Shipping on orders over $35. Details
You Save: $3.22 (21%)
View Steve Peterson's profile
Steve Peterson
387 posts in 3163 days
#6 posted 04-01-2017 10:33 PM
My bandsaw had a mixture of both sealed and shielded skateboard bearings when I got it on CL. Some of each type have locked up and need to be replaced. I suspect that the seal may wear out because of the high speed on a bandsaw. Shielded would have less friction, but obviously would allow more dust to get through.
They are cheap enough that I may get some of each and see which type lasts longer.
-- Steve
Spoctor
8 posts in 795 days
#7 posted 04-01-2017 10:39 PM
Thanks to all who have responded to my post! My suspicions have been confirmed that sawdust is the culprit. I have also been able, with your suggestions, to find out where I can get inexpensive sealed replacement bearings. I can’t imagine why Sears wouldn’t put such inexpensive sealed bearings on their bandsaws. Sealed bearings may not last forever, but I’ll bet they last longer than unsealed ones.
View MrUnix's profile
MrUnix
6845 posts in 2279 days
#8 posted 04-01-2017 10:44 PM
High speed? LOL – those will be running as slow as molasses compared to their max ratings.. The typical 608’s and 6200’s are rated for speeds in the tens of thousands RPMs. The only reason shielded bearings (instead of sealed) are used is because they have less rotational friction than their sealed counterparts, which is desirable for that application where there is just a light friction touch between the blade and bearing.
