Gluing wood to glass
Forum topic by PeteJacobsen posted 968 days ago 3663 views 0 times favorited 7 replies Add to Favorites Watch
View PeteJacobsen's profile
PeteJacobsen
15 posts in 1954 days
968 days ago
Topic tags/keywords: question
My wife asked for a nice piece of wood trim along the bottom of her 6’ bathroom mirror. The backing of the mirror is coming off at the bottom, and looks ugly. I had a nice skinny maple board from which I made a strip about 1 3/8” high and 1/4” thick, and of course 6’ long. My original plan was to tack it just below the mirror, but I realized the tile comes right up to the mirror. New plan: glue it to the mirror.
Question: what kind of glue?
-- At war with my faults, at peace with my neighbors
7 replies so far
89108 posts in 1774 days
#1 posted 968 days ago
There are some mastic’s that are use to glue mirrors to walls I’m sure that will work .If your local box store doesn’t carry it ask about it at a glass shop.
View interpim's profile
interpim
1117 posts in 1655 days
#2 posted 968 days ago
View GMman's profile
GMman
3885 posts in 1895 days
#3 posted 968 days ago
Silicone will work well, what Jim mentioned is a black silicone I have used it, it will never come apart you would have to break it to take apart but regular clear silicone would work better in your case.
PeteJacobsen
#4 posted 968 days ago
I’m going to go with clear silicone, partly because I’ve got it on hand. Thanks, interpim, for pointing out “thistothat.com”, an site I’ll definitely bookmark!
Pete
View rivergirl's profile
rivergirl
3197 posts in 1035 days
#5 posted 968 days ago
They make some new silcone glue stuff- just saw it last week- the guy at the store said it glues like crazy. It is in a tube like silicone. It comes in clear too. I wish I could remember the name of it. He said contractora are using it instead of liquid nails.
-- Homer : "Oh, and how is education supposed to make me feel smarter? Besides, every time I learn something new, it pushes some old stuff out of my brain."
View poopiekat's profile (online now)
poopiekat
2907 posts in 1931 days
#6 posted 968 days ago
My father built my sister a dollhouse for her Barbies circa 1966. He used Elmer’s white glue to glue real window glass to the inside of the plywood walls. It’s still holding, 34 years later!!
View Gofor's profile
Gofor
470 posts in 1984 days
#7 posted 968 days ago
If the above does not work, the automotive stores sell the glue used to stick rear-view mirrors to windshields. Only caveat is that you probably will never be able to remove it, so line it up right the first time. If you use it, I would just use small dabs to secure it and then silicone the seam edge. In this vein, 2 part epoxy will also work and probably would be less expensive.
Whichever you use, take care not to get any on the back side of the mirror, only on the surface glass. Getting it on the back side may cause a reaction with the reflective layer that could spread into the visible area.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
