The Right wood burning stove?
Forum topic by BillieAchilleos posted 10-24-2010 06:51 PM 1755 views 0 times favorited 6 replies Add to Favorites Watch
View BillieAchilleos's profile
BillieAchilleos
7 posts in 3689 days
10-24-2010 06:51 PM
Hello, I’m setting up my first workshop and am torn between what kind of stove I want to heat it?
The building is at the back of my uncles garden and so has no direct plumbing or heating system. My hands are terribly sensitive to the cold and good heating is imperitive for me to work in the winter months. I wasn’t keen on the idea of using electric heaters because of the cost. And prefer to put my waste to some better use by burning it. My current options are:-
A RELAX off cut and sawdust/shavings burner – it’s ugly, but practical? I’d love to hear from someone who has one of these. http://www.relaxstoves.co.uk/
A wood burning stove – I’m afraid I find them alot prettier than the RELAX burners. I really shouldnt be thinking about asthetics over function, but I’m a prop maker, not just a wood carver and have doubts on how much saw dust I’ll produce to fuel a RELAX burner. But I often work places where I can get plentyful wood offcuts for free. http://cgi.ebay.co.uk/Birch-Pot-Belly-6kW-Wood-Burning-Workshop-Stove-Stoves-/160437324880?pt=UK_HG_FireplacesMantelpieces_RL&hash=item255acf4c50 < Something like this?
The thing about both stoves is that they need to be a certain distance from the wall and their position will be fix. The room isn’t that big and in the summer I might benifit from extra space if I had a gas heater where I get gas canisters refilled at petrol stations. I’d prefer to be using renewable fuel and using my off cuts and waste from the larger prop shops I work for. I also wouldn’t have to go through the hastle of installing a flue. I’m very torn, please help!
View lwllms's profile
lwllms
555 posts in 3246 days
#1 posted 10-25-2010 03:39 AM
Billie,
If I was you, I’d get the Relax. The cast iron ones are probably cheap imports. First, check about your local business or building codes. I’m not familiar with British codes at all and have no idea what they may require.
View jusfine's profile
jusfine
2422 posts in 2890 days
#2 posted 10-25-2010 04:57 AM
Billie, this may not be much help, but I actually like the look of the Relax stove.
As far as I’m concerned, there is nothing like the feel of heat generated by real fire.
All the Best with your choice!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View measure2x's profile
measure2x
50 posts in 3098 days
#3 posted 10-25-2010 10:42 PM
Billie,
I have 2 wood stoves in my home and electric heat (hey, I,m in Canada, eh?) and the stoves produce great heat. One problem many people have is that their stove is really too big for the space and they operate it at a low temp. and have problems (safety) with creosote. You mentioned your room isn’t very big—- for a small space when you factor in the cost of a safe chimney (often more than the stove), electric heater may be the best. The recent electric space heaters are pretty efficient (my $69.00 Seabreeze Smart Thermaflo™ 1500W Pulse Action Heater Fan Model: SOH3003TA works well and automatically adjusts output and claims 33% less cost; + there are radiant heaters that will heat you & your tools but not the air.)
Suggestion: Keep it simple—Why not get an electric heater or two & try them out for a day or so—- if you are not happy most stores would provide a refund.
best wishes,
Terry
Fredericton, NB Canada
-- Terry, Fredericton, NB Canada
View Dan's profile
Dan
3630 posts in 2845 days
#4 posted 10-25-2010 10:56 PM
Have you thought about an outdoor wood stove? I don’t know if they have them there but I have seen outdoor wood stoves that vent the heat inside. This would save you your space.
-- Dan - "Collector of Hand Planes"
View hairy's profile
hairy
2655 posts in 3497 days
#5 posted 10-26-2010 02:14 AM
Many years ago, I had a 2 car garage . I wasn’t ww’ing then, but I was doing cars and motorcycles in there.
I had a small,cast iron woodburning stove for heat. I kept a fan behind it to move the air.
Safety wise, it takes a lot of vigilance, but it can be done.
In reality, I didn’t get a whole lot done there in the winter. I’d get a good fire going, and a little work, but mostly dealing with the fire.
I would suggest a propane heater. It doesn’t take up much space, can be moved around as needed, and would consume less of your time.
-- My reality check bounced...
BillieAchilleos
#6 posted 11-02-2010 09:23 PM
Thank you so much, everyone is so lovely and helpful on here.
I think I’m going to get a gas heater, like the one Hairy suggested. That way in the summer months I can tuck it away and utilise my little work space better.
I do love a good REAL fire though. My workshop is at the end of my Uncles garden, and he’s got an open fire in the house, so my offcuts can still go to come use.
I’m looking forward to finally being able to get down to some wood work again. Thanks for all your help! xx
