Awesome new way to make Beaded Face Frame w/pics & vid
Forum topic by ThatDaveGuy posted 10-24-2010 02:45 AM 6571 views 0 times favorited 1 reply Add to Favorites Watch
View ThatDaveGuy's profile
ThatDaveGuy
4 posts in 3176 days
10-24-2010 02:45 AM
Hello everyone,
I have been working on the design of this machine on and off for about two years.
As of tonight, it is finally operational.
It is a 1975 Delta RAS12 12” radial arm saw with custom notching head that has shear and negative rake. There is a digital height gauge on the side that is accurate to 1/200”.
Run the bead on the router table. Knock corner off bead with micro adjustable sled.
Notch other end with pneumatically operated notcher.
IT’S ALIVE!
Thanks for looking,
David – Tool Guy
1 reply so far
View TJ65's profile
TJ65
1381 posts in 3287 days
#1 posted 10-24-2010 09:12 AM
congrats on your achievement.
Now you know you can do almost anything
if you have the will power to keep plugging away at making that for two years :-)
now you have to use it and make something!!
-- Theresa, https://www.facebook.com/derrymore/
