Pen mill size for Sierra pen
Forum topic by yellowtruck75 posted 10-23-2010 06:40 PM 1143 views 0 times favorited 2 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 3034 days
10-23-2010 06:40 PM
What size pen mill do I need for the Sierra pen? Will the 7M mill I have work for it?
2 replies so far
View interpim's profile
interpim
1170 posts in 3426 days
#1 posted 10-24-2010 01:00 AM
I’ve used the 7mm mill before by using the bushing for the kit on the bottom of the mill. Make sure you have it flat against the drill press table, with the end of the mill already in the bushing before you turn on the press. So essentially, you’ll have your blank on the mill shy of the cutter head, the bushing in the bottom with the mill bar inside the bushing to center it… Take it slow when you are cutting as you could chatter the mill on the wood messing up your blank.
You could also do something similar by making mini-bushings that will fit inside your tubes, but have a 7mm hole for the mill shaft. Same idea, but will make less of a chance of chattering.
-- San Diego, CA
View DurocShark's profile
DurocShark
65 posts in 2738 days
#2 posted 10-25-2010 01:08 PM
The pen mill sets have one that fits the sierra/wall street ii (any pen you drill the blank with a 27/64” bit.)
-- -Don
