Squeeze out clean up before staining
Forum topic by woodgu posted 10-23-2010 12:54 PM 1119 views 1 time favorited 4 replies Add to Favorites Watch
View woodgu's profile
woodgu
63 posts in 2771 days
10-23-2010 12:54 PM
Topic tags/keywords: finishing
I know that prevention is the best cure, but despite my best efforts, occasionally I will have some glue marks on a joint or something that becomes very obvious when applying stain.
A friend recently took a piece he built for the church to a cabinet shop to have it professionally stained and finished. The cabinet maker remarked that there were a few glue spots, but he took care of them. When we asked how he dealt with it, he said he has a mixture he concocted over the years that helps disolve the glue. He would not divulged his secret.
Have any of you heard of something like this? A cabinet scraper is what I have found most effective on solid wood, but plywood is a challenge since the laminate is so thin. Someone mentioned warm white vinegar does a decent job.
How do you approach cleaning up cured glue that you had missed?
-- Phil G
View knotscott's profile
knotscott
8012 posts in 3373 days
#1 posted 10-23-2010 01:28 PM
Usually the time I find cured glue that I missed, it’s already been stained and sticks out like a sore thumb. Historically, my choices have been to sand the area down and try again, or to dab a little furniture marker over it to disguise it.
View Moron's profile
Moron
5032 posts in 3890 days
#2 posted 10-23-2010 01:49 PM
if its wet glue, then I use a damp rag and clean it off, putting a pencil mark around it so I remember to sand it again (water raises the grain and ir shows up blotchy after staining)
if the glue is dry I use a very sharp chisel for corners, a cabinet scraper for flats. With the chisel I get under it, in both directions (ie., a corner/joint) and the glue should just fall off,then re-sand
View ChuckV's profile
ChuckV
3118 posts in 3524 days
#3 posted 10-23-2010 02:09 PM
I take off as much excess glue as I can after 20 – 30 minutes, when it is just the right gooey consistency (I use Titebond III). I have a cranked-neck chisel that is devoted to this to avoid getting glue on my other chisels.
There are sometimes spots that I do not see until after finishing. I have had good results with Huckleberry’s idea:
http://lumberjocks.com/Huckleberry/blog/15775
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
woodgu
#4 posted 10-23-2010 07:42 PM
I will be staining a project later this week. I hope I will have no unknown glue spots, but if I do, I have a few more ideas to employ. I especially like Mr. Huckleberry’s suggestion.
Thank you everyone!
-- Phil G
