Ideas for holding mini plane irons in sharpener?
« back to Hand Tools forum
Forum topic by Robodie posted 03-30-2017 09:37 AM 532 views 0 times favorited 7 replies Add to Favorites Watch
View Robodie's profile
Robodie
1 post in 1176 days
03-30-2017 09:37 AM
Topic tags/keywords: mini plane iron sharpening honing
Hello to all!
Hoping someone here can offer guidance / ideas for holding mini plane irons in a General Tools Chisel & Plane Iron Sharpener. It’s not the best guide, but works decently will for normal sized irons—however, due to the clamping mechanism (pic attached) I cannot for the life of me figure out how to hold these tiny irons.
I bought a couple sets of these mini planes at Harbor Freight, mostly for work on instruments, and like any HF tool, they need some fine tuning.
The irons are tiny (approx. 2 7/8” by 1/2” by 1/16”, pics also attached) and the clamp is far too big to allow enough length for the edge to touch the stone / paper.
I’ve tried fashioning a couple of jigs with utter failure, but I KNOW there has to be a way.
I’ve already tried hand-sharpening, which was quite successful—in removing a fair amount of knuckle skin.
I can’t afford a better guide at the moment, and the wooden ones I made worked okay-ish but sanded the bottom of the tool more than the iron.
Any thoughts would be greatly appreciated. Cheers!
-- Thank you, Grampa, for teaching me all that you did. Even though your gone, I'm still learning, and will make you proud with my heirloom hands.
7 replies so far
View HorizontalMike's profile
HorizontalMike
7770 posts in 3154 days
#1 posted 03-30-2017 10:04 AM
IMO, forget “jigs” and hold it with your fingers and hand-sharpen it on a flat stone, 600/1200-grit sandpaper, etc.
View Dave Polaschek's profile
Dave Polaschek
3089 posts in 822 days
#2 posted 03-30-2017 10:18 AM
For spokeshave blades, I use a Veritas small blade holder which holds the blades in it using (strong) magnets. Maybe you could rig up something similar? Take a look at the pictures of it – there’s not a whole lot there.
-- Dave - Minneapolis
View OSU55's profile (online now)
OSU55
2033 posts in 2229 days
#3 posted 03-30-2017 12:03 PM
Tape the small iron to a larger iron and clamp the large iron in the jig.
View JRsgarage's profile
JRsgarage
336 posts in 749 days
#4 posted 03-30-2017 12:27 PM
any cheap eclipse type sharpeners will hold them tight….use the inner grooves and really tighten with screwdriver. the older veritas sharpeners are good too…just check for squareness from shifting
-- Two is One, One is None
View LittleShaver's profile
LittleShaver
455 posts in 859 days
#5 posted 03-30-2017 12:40 PM
I have done this same set. Ended up using fingers to hold blades.
-- Sawdust Maker
View WayneC's profile
WayneC
13800 posts in 4337 days
#6 posted 03-30-2017 01:49 PM
Worksharp would likely work well if you have access to one.
View corelz125's profile
corelz125
590 posts in 1216 days
#7 posted 03-30-2017 11:48 PM
I used my worksharp to sharpen my mini blades. Got them done in no time
