Grizzly jointers stock
Forum topic by kur1j posted 03-29-2017 07:08 PM 2390 views 0 times favorited 16 replies Add to Favorites Watch
View kur1j's profile
kur1j
14 posts in 572 days
03-29-2017 07:08 PM
Topic tags/keywords: grizzly jointers jointer
So I was planning on getting a G0490x but it is out of stock. Does anyone know if they are just out of stock or if they are refreshing the line?
The only question I have regarding the machine itself is why can the 0490xw can joint a 2 inch shorter board (8 vs 10 for the 490x). Is that just due to the parallelogram design requiring larger boards to joint correctly?
Also, does anyone know where I can get a 10% coupon? I can’t seem to find one online or do they only do that during some type of holiday?
16 replies so far
View jmos's profile
jmos
868 posts in 2518 days
#1 posted 03-30-2017 12:19 AM
I recently (~6 months ago) bought a G0490XW. At the time they had just discontinued the G0490 and released the G0490XW. I can’t say for sure, but I doubt it would be a refresh this quickly.
Not quite following your second question; both are 8” jointers.
Can’t help with the coupon, I’ve never gotten one from them.
-- John
kur1j
#2 posted 03-30-2017 12:25 AM
I recently (~6 months ago) bought a G0490XW. At the time they had just discontinued the G0490 and released the G0490XW. I can t say for sure, but I doubt it would be a refresh this quickly.
Can t help with the coupon, I ve never gotten one from them.
- jmos
Thanks for the feedback. What I meant by the second question was if you look at the specs of both jointers the only difference is the “shortest jointable board” (length wise) the 490x is 10” and the 490xw is 8”. Just wasn’t sure why
View jmos's profile
jmos
#3 posted 03-30-2017 01:01 AM
I’ve got nothing for that. The only difference between the G0490x and the G0490XW is the cutter head. I actually bought a G0490X and changed the head to make it a G0490XW (long story I blogged if interested.) Sounds like a typo.
-- John
kur1j
#4 posted 03-30-2017 01:27 AM
I ve got nothing for that. The only difference between the G0490x and the G0490XW is the cutter head. I actually bought a G0490X and changed the head to make it a G0490XW (long story I blogged if interested.) Sounds like a typo.
- jmos
Yeah, I’m completely confused. The grizzly website shows the 490x is the parallelogram with spiral cutter head. The 490xw is just the parallelogram bed.
https://imgur.com/gallery/Njwr6
19084 posts in 2005 days
#5 posted 03-30-2017 01:39 AM
I would never joint a 10” or 8”piece no matter what the spec sheet says. Otherwise, the difference must be in what the gap is between the infeed and outfeed.
kur1j
#6 posted 03-30-2017 01:46 AM
- firefighterontheside
So I think the specs are wrong in the website. What is the differences between the 490xw and the 490x?
View mrg's profile
mrg
828 posts in 3148 days
#7 posted 03-30-2017 03:10 AM
Difference is number of cuts per minute rpm of cutter head and parrallelagram bed.
-- mrg
kur1j
#8 posted 03-30-2017 03:52 AM
- mrg
If you compare the G0490X and the G0490XW here (http://www.grizzly.com/compare?category=Jointers&preload=G0490X|G0490XW||G0490), they both have parallelogram beds, are essentially identical. The ONLY difference I can see is that the spiral head on the G0490XW is slightly smaller (3in.) vs the G0490X (3 3/8 in.). This obviously makes the G0490XW cut slightly faster. Other than that I see no difference in the two. Is that even of concern those 2200 Cuts per minute?
View alittleoff's profile
alittleoff
541 posts in 1425 days
#9 posted 03-30-2017 04:46 PM
The 490x has a little larger base also. The coupon didn’t come out in the catalog this year, been trying to get one myself. According to the lady at grizzly the the GO490XW will be available in may and the XW in April I believe is what she said.
Gerald
kur1j
#10 posted 03-30-2017 05:21 PM
The 490x has a little larger base also. The coupon didn t come out in the catalog this year, been trying to get one myself. According to the lady at grizzly the the GO490XW will be available in may and the XW in April I believe is what she said.
Gerald
- alittleoff
Oddly enough i saw this posted that someone got one a few days ago in email when they ordered the catalog and that was only a few days ago. https://www.reddit.com/r/woodworking/comments/613e7l/free_coupon_grizzly_10_off/?st=J0WO0PVO&sh=d0189fdf
View woodman88's profile
woodman88
144 posts in 2797 days
#11 posted 03-31-2017 12:01 AM
I just recently bought 2 g0490x they are not discontinued just back logged I waited about 1 month if you want one you have to order it to get on the list. I was told by Grizzly rep only difference in zw is the manufacturing facility. The overall weight and amp on the motor is different
kur1j
#12 posted 03-31-2017 12:17 AM
- woodman88
The site specs of the 490x and 490xw are the same except the cutting head is smaller on the 490xw. Everything else is the same according to the specs sheet.
woodman88
#13 posted 03-31-2017 12:48 AM
read aigain yes cutterhead is different but so is weight and amperage and they dont tell you but made in a different plant
kur1j
#14 posted 03-31-2017 01:14 AM
- woodman88
Sorry you are right, I was looking at the G0490 and the G0490X. Interesting that they put a different motor in the G0490XW.
woodman88
#15 posted 03-31-2017 01:42 AM
you will be happy with the 490x plus free shipping
