sealing a paint
Forum topic by SuperDave02 posted 10-23-2010 12:49 AM 985 views 0 times favorited 6 replies Add to Favorites Watch
View SuperDave02's profile
SuperDave02
141 posts in 3470 days
10-23-2010 12:49 AM
I just finished making some built in bookcases and I painted them with the same interior paint as the walls of my house. But it is really prone to scuffing. Can I use a varnish of poly to seal it???
-- David South FLorida http://rockingrrustics.blogspot.com/
117417 posts in 3816 days
#1 posted 10-23-2010 12:53 AM
If in doubt put a coat of dewaxed shellac first and a light scuff with some 220 and your good to go.
View canadianchips's profile
canadianchips
2616 posts in 3236 days
#2 posted 10-23-2010 03:08 AM
I have had really good results using satin finish polycrylic over painted surfaces.
View lseventom's profile
lseventom
2 posts in 3012 days
#3 posted 10-23-2010 03:30 AM
Defenitely you can use an acrylic WB clear. Olympic, Minwax, etc. Keep in mind that some WB acrylics are are not “water” clear, 2 good coats of clear should do you good.
lseventom
#4 posted 10-23-2010 03:32 AM
PS::: if you sprsy finish, I would recommend using the PPG Breakthrough product line. It’s absolutely great from great sand sealers to top coats that don’t mar and are extremely chemical resistant! + they’re all WB! Very fast dry. The sand sealer sands just like lacquers.
SuperDave02
#5 posted 10-24-2010 10:13 PM
Well….I tried the polycrylic, and it did change the color, its noticably darker now. So I think I will put on a second coat, then repaint it. That way if it is scuffed it will have the protective layer just under it. Maybe it will work
View stefang's profile
stefang
16214 posts in 3573 days
#6 posted 10-25-2010 06:08 PM
Polyurethane works well and if you use a good quality water based poly it won’t change the color. I just replaced a kitchen counter that was painted and protected with 3 coats of poly. It has stayed very nice for the last 8 years with daily use. A film finish over paint is hard to repair, though we didn’t have the need over all those years.
